Changed Rear Brakes- Oil Leak??
Changed my rear pads & rotors on the Maxima. I used a caliper piston compressor to move it back into place. Not sure If it went too far, because some oil started coming out from the caliper boot. Did it spring a leak or is this normal/ok?
The rear maxima calipers are known to go bad early and seeze up
-matt
No fluid should come out from the piston dust boot. Like matty said, only bleeder screw or disconnecting brake line.
I guess your dust boot is worn, and you should purchase a caliper rebuild kit which contains new dust boot, new O-ring. Fix the probem ASAP, or else you will lose pressure in the brake system.
Did you have the tool that allows you to spin/turn the caliper piston back in, or did you just push it back in. Either way it should not be leaking any break fluid.
Even though the tool is mechanical, sometimes it takes a careful look/see to make sure one's using it properly....my .02.
MatthewsMaxima
Sep 11, 2015 03:21 AM
RealityCheck
Aug 5, 2015 06:18 AM
