Redline MT90 really is worth it
When I changed my clutch this summer, I put some 80w90 fluid in my transmission. Normal stuff, said it was for gl4 and gl5 applications iirc.
Anyway, since its gotten colder in Kansas, my gearbox has been a notchy rubbery pos and really really tough to get into gear.
I broke down and bought 5 quarts of mt90 on the web for 7 bucks/bottle with like 6 bucks shipping to kansas. It arrived in 3 days from Pennsylvania.
Put it in on Sunday.
WHOA.. this is by far the biggest change I've felt in my car in a LONG time.
Even with 24 degree temps, windchill in the single digits, my gearbox feels tight and crisp, no more notchiness, no more rubbery feeling until it pops into gear. Glad I finally did this. I know my car thanks me for it. The fluid is very fluid even at cold temps so far, no more thick honey feel to my transmission.
If you dont have it already, get it.. its worth every penny.
I just replaced mine for the same reason. Notchy on cold mornings. MT90 from Summit, under $50 shipped to my door in 3 days. Notchy shifting is completely gone. The wife even noticed.
Before I got the MT90 I went to the Nissan dealer in town to try to get GL-4. Their parts department said..... "We upgraded to GL-5" and showed me a bottle of Pennzoil GL-5. I told him I was looking for GL-4 and he said that it was the same thing and that it would be fine. I just smiled and walked out.
Originally Posted by hightuner
Can this stuff be used in -40C winter ???
i am looking to flush mine tx
I think all the gear lube is synthetic based
here's a link: http://myoilshop.com/AutoPrds.html
I'm using MT90 and like it. There's nothing wrong with switching to synthetic, and it's pretty much always a good thing to change the transmission fluid to redline or some other simialr synthetic.
I think the bad thing about GL5 stuff was that it eats away at the synchros, IIRC.
Originally Posted by whitemax21
I know this may sound stupid, but a mechanic once told me that changing the transmission fluid in a manual transmission can sometimes lead to problems? Anyone heard this before?
I wouldn't consider hiim a mechanic... at all.....wow
It's not recommended to swtich back to converntional fluids once you start running synthetic. There have been some people whom complain of notchier shifting in colder weather with MT-90, I being one of the latter, perfer Amsoil tranny fluid...however either will make a noticable improvment in shifting.
Yeah the GL fluid helped my synchros disintegrate at 120k miles...no longer do I have the privelege of shifting into first unless the car is completely stopped. The clutch evaporated, too, which I also believe contributed to it. Should have let the clutch bed-in longer, and switched to MT90 when I changed it...looking for a helical LSD now along with a new tranny.
i have over about 110k on my max....the tranny is leaking a little bit due to old age im guessing...not enough to see drops tho...only oil on the side of the tranny......would my tranny leak more if i change to mt90 since mt90 is synthetic and thinner?
update on feel of 5 speed tranny with MT-90 fluid:
if i get in car in morning without proper warm up (to move my car), its a little notchy, but that can also be because of my b&m sts and *** shifter bushing.
however, if i remote start and let car sit for a little, and start driving, things are super smove. I have had my fluid in for over 10k miles and no leaks, no problems thus far. Only thing i'm not happy with is when in gear, shifter can move a little from left to right. But i think thats due to a worn out spring? any recommendations on how to keep shifter as stiff as possible when in gear? this is not a serious problem but to make things perfect, just wondering.
So does any one tell those people that say GL5 is better that it eats up syncros? Thats usually good info for an idiot part pusher to know. They will either insist on GL5 if they are evil or actually tell people to get gl4...I do but then thats just me
~Alex
~Alex
I just broke down a maxima tranny and I saw NOTHING to suggest a GL-4/GL-5 fluid is going to damage them. I'm putting in Neo 75w90HD (GL4/GL5) when I get it rebuilt and I'm confident it will go 200k without an issue.
I suspect the no-GL5 story got kicked off because somewhere some Nissan rep only saw GL-4 listed. There are in fact Nissan TSBs listing GL-5 as the recommended lubricant (ref. NTB94-100). The chart in that TSB is here.
Dave
Dave
Forge277
Jun 13, 2016 09:26 PM
Dasmith
Sep 23, 2015 08:28 PM
