2000 maxima gxe making a whinning noise somewhere in the engine when i turn it off.
This problem is driving me nuts..when i turn the car off, it makes this whinning noise from somewhere in the top back portion of the engine...and when the car is in park..and i hit the accelerator, the car makes the whining noise and it stalls..any ideas?
My mechanic cleaned the MAF, the car ran better for a little bit...but now the RPM drops even on drive, which it never did before...maybe it's time for a new maf? i never thought about the motor mounts..do they make a whinning noise when car is turned off?
thanks
thanks
Every tech thread a read- someone is saying--replace your maf or "I just replaced my maf, that wasn't it). - I'm still not able to start a new thead, awaiting activation or something..tick tock.....Anyway's there is a way to test your maf before just throwing money at it. There are probably--(at least on all mafs ive seen) 4 wires coming from maf. One is a power wire, one power ground, one signal, and one signal ground.(If my memory serves me correctly) I'm sure it's posted here somewhere how to check the maf signal with a voltmeter before replacing. Do some searches, I honestly wouldn't replace something knowing it's probably not the cause......
....Maybe I'm making the parts suppliers/moderators mad in here and their not activating my nic????
Bad electronic motor mounts can do this. Read this TSB, it may help:
http://maxima.theowensfamily.com/tsb/NTB01-010.pdf
My mechanic was able to find the maf here locally for $83..he replaced it..and now problem has been solved..no more stalling at all in parking or neutral...I not changing the engine mounts he said..it was no big deal..
thanks for all your help..
Originally Posted by zmaxuser
I think you are right on the money...that is my problem..the buzzing sound..I will call my mechanic now and let him know about this TSB. thanks a lot.
jholley
Aug 11, 2015 09:38 AM
kirkhilles
Aug 8, 2015 10:53 AM
bassmann
Aug 3, 2015 07:53 PM
