Car all of the sudden begins to bump in muffler
Old Nov 30, 2005 | 08:18 PM
lokobreed's Avatar
My car is a 95 Nissan Maxima SE.
I was driving home today afer an interview and a stop light I felt my car start to bump (like a shivering sense) and when I would let go off the brake it would in a sense bump or bounce forward.
When I got home I got out of the car and looked at the hood and the engine seemed to be somewhat bouncing (like lightly moving more than normal) as well as the muflee. the mufler was bouncing air out.
what is causing this and how serious is this?
Old Nov 30, 2005 | 09:26 PM
Fr33way™'s Avatar
Wild for Width
misfire?
Please try and conjure up a more detailed explanation so people can help you.
Old Nov 30, 2005 | 09:36 PM
killerVQ30DE's Avatar
Sounds like it could be your motor mounts...
1. Open bonnet of your car so you can see engine when in drivers seat
2. In Drive with your foot on the brake rev the engine a bit
3. Watch how much your engine shifts.. if its a lot, its your mounts
Old Nov 30, 2005 | 09:47 PM
the_3d_man's Avatar
No... i don't think this is motor mounts (though they MAY be bad...) if my understanding of his english is correct.
what he is saying is that the engine is vibrating hard and the exhaust is sputtering.
he has a misfire.
Old Nov 30, 2005 | 10:27 PM
NmexMAX's Avatar
dot dot dot ...
on the on motor mounts..
That wouldn't cause sputtering or put put from exhaust.
Old Dec 1, 2005 | 05:20 AM
MaDMvD's Avatar
What's a bonnet and how would you be able to see the engine while sitting in the car?
Old Dec 1, 2005 | 08:14 AM
lokobreed's Avatar
Yes vibrating is a better word. The engine seems to be vibrating more than normal and the muffler as well. It aslo puting out exhaust in short puffs.
What is misfire? Is it bad? How much is it to fix?
Is it safe to drive and how did it occur?
Old Dec 1, 2005 | 08:44 AM
2 Da Max's Avatar
is it a rattling noise? i have the same problem, its the muffler
put the car in DRIVE on a hill or something, pull up the handbrake, or let one of your friends sit inside and hold the brake while the car is in drive
go to the back of your car and youll hear the muffler rattle
Old Dec 1, 2005 | 08:45 AM
lokobreed's Avatar
I will go see if I hear rattling noise, but my muffler is brand new. Not even 5 months old yet.
Old Dec 1, 2005 | 08:51 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
sounds like a misfire or hesistation in the coil packs.
Old Dec 1, 2005 | 08:55 AM
lokobreed's Avatar
could it be the pipes leading up to the muffler?
Old Dec 1, 2005 | 08:56 AM
lokobreed's Avatar
It didnt seem to be much rattling. The muffler was just pumping out colored exhaust in puffs. The engine is rattling also.
What causes a misfire? Is it xpensive to repair?
What is the coil packs?
Is it safe to drive?
Old Dec 1, 2005 | 09:04 AM
the_3d_man's Avatar
wait a minute... colored exhaust... you said nothing about this earlier! .. is it blue?
and did it used to do this?
Is the car shaking more than normal?
if it is you have a misfire most likely, although this colored exhaust might mean you're burning oil... which is bad
also... do you have any codes?! I can't believe no one has asked yet... if it's misfiring you should have a check engine light.
or at least something stored with no light.
go check! all you need is a screw driver!
Old Dec 1, 2005 | 09:08 AM
lokobreed's Avatar
I will go check. The exhause is like dark grey.
The car is indeed shaking more.
What exactly is a misfire?
And is it expensive to fix?
pmohr's Avatar
No more Maximas...
...what color?
Blue - Oil
White - Coolant
Black - fuel (too rich)
Old Dec 1, 2005 | 09:11 AM
lokobreed's Avatar
I would say its more of a white. Does that mean my coolant is bad?
MaDMvD's Avatar
Not true. I've had a misfire for about 6 months now with no code.
Old Dec 1, 2005 | 09:12 AM
pmohr's Avatar
No more Maximas...
It means you're burning coolant.
Old Dec 1, 2005 | 09:25 AM
lokobreed's Avatar
Ok I tried to get those 2 "pop in" black screws out but I cant. I bent the hell out of one of them. I dont wantt o damage anything trying to get them out. I stuck the flat head in there and treid prying it out but no luck.
When I turn off the car I notice it goes "shhhuch" and then a little later does the sound again.
Old Dec 1, 2005 | 09:26 AM
lokobreed's Avatar
Is a misfire bad? I mean it is vibrating heavily. How much is it to fix??
Old Dec 1, 2005 | 10:12 AM
lokobreed's Avatar
please help with more info on misfiring and how much it is to fix.
Old Dec 1, 2005 | 10:18 AM
lokobreed's Avatar
COuld this have been cause by putting regular unleaded in on top of premium unleaded?
Old Dec 1, 2005 | 10:22 AM
lokobreed's Avatar
WHen my car is just sitting in park running (idle I believe) it is running at about 1500 rpm is that bad?
Old Dec 1, 2005 | 10:30 AM
NmexMAX's Avatar
dot dot dot ...
5 posts .... If you do not know misfiring is ... More in the stickies...
Old Dec 1, 2005 | 11:20 AM
lokobreed's Avatar
Can you tell me which sticky I should look in? Because I could not find it
Old Dec 1, 2005 | 11:29 AM
NmexMAX's Avatar
dot dot dot ...
ECU sticky
http://forums.maxima.org/showthread.php?t=104931
If one cylinder is misfiring the problem is spark or fuel. A misfire due to a spark problem usually results in a Service Engine Soon light
Basic Car Question Sticky
http://www.howstuffworks.com/category.htm?cat=Auto
IMO
Common sense ALMOST > You
Old Dec 1, 2005 | 11:32 AM
MaximaSE96's Avatar
Maxima Owner
i am gonna take a shot at coil pack or injector.....
Old Dec 1, 2005 | 11:37 AM
lokobreed's Avatar
If one cylsinder is misfiring the problem is a spark or fuel?"
-- How do I know if a cylinder is misfiring? I am not very car smart... sorry
NmexMAX's Avatar
dot dot dot ...
Spark OR Fuel
Old Dec 1, 2005 | 11:41 AM
MaximaSE96's Avatar
Maxima Owner
Originally Posted by NmexMAX
Spark OR Fuel
i am too lazy to read the entire thread even the small ones so i read the 1st post and comment......
PS....my old 96 maxima did the same thingk it ended up being 2 coils packs
Old Dec 1, 2005 | 11:47 AM
NmexMAX's Avatar
dot dot dot ...
http://auto.howstuffworks.com/search.php
I got here by typing "Spark Plug" from the link I proveided...in the earlier [post, something you should do ..
I take it back
Common sense > you
Lakersallday24
Jun 16, 2019 01:35 AM
erictown
Aug 20, 2015 08:01 AM
Samedi
Aug 13, 2015 04:05 PM
Gsantos79
Aug 8, 2015 07:41 AM
