Mass air flow sensor bad, what do I do to get a new one?
With out paying the $400 at the dealer. Where can i get another MAF sensor?
At 68,000 miles this car is getting to be an expensive pain in the ***. I need a new Evap. control valve in the rear, mass air flow sensor AND brakes turned for the SECOND time.
Originally Posted by Indigo
Do you know how hard it is to replace it? Is it something fairly easy that i can do?
If ya wanna save some cash:
http://forums.maxima.org/showthread.php?t=348395
And stop going to the dealership.
Originally Posted by mtrai760
You can also get them fairly cheap from courtesyparts.com Its easy to replace, 10 minutes max. 4 bolts, a clamp, and disconnect the wiring harness.
Just buy an 01 Maf, and swap the thermister out of the old one to the new one. $87 fix.
James
Originally Posted by jimmycapp
Its even faster if you leave the tube in and just remove the two torqs screws, and pull the sensor out the top.
James
James
Originally Posted by danger300z
I though it was a direct plug and play?? I dident know you had to swap out the themister?
See link in post #5.
FlaMark
25
Aug 28, 2015 10:15 AM
bc992164
Aug 26, 2015 12:19 PM
doobadoo
Aug 15, 2015 06:43 PM
