Got 357 miles from a full tank!
I went on a road trip this weekend and got 357 miles on a little over 15 gallons of gas! I don't think I've ever seen my car go more than 260 miles on a full tank in stop and go conditions. When I consider that I'm only getting about 15-16mpg in city driving, that was amazing!
Oh noes, another gas thread!
I was getting ~370 city miles/tank before it started getting cold, now it's dropped down to about 310... You'd think it would get better, but then again, VQ + cold air = lead foot!
Yea, I got sub 400mi/tank in word possible conditions... normally I'm well above 400mi/tank. When I went on a trip to maine this summer I averaged 29mpg..
A month ago I was curious if driving "nicer" (shifting at lower RPMS, taking car out of gear and coasting when slowing down and in other scenarios, basically limiting the RPMS whenever possible... driving a bit slower on the highway then I normally do etc.) I did this for two entire tanks and got horribly worse mileage then I do with my normal driving of medium acceleration normally, shifting at 3500 RPM normally, sometimes a bit higher when the urge comes.
The only reasoning I could come up with was that because I was accelerating slower to get up to speed that the length of time I was on the gas to get up to speed offset any other savings, whereas when I accelerate faster I can get into a higher gear for maintaining speed much quicker (thus getting to a constant low RPM rate faster.)
Go figure.. going fast makes you save gas (atleast for me.)
Originally Posted by GREENlight
Over 400.....WOW! I need to find out what's wrong with my car.
No one can fit 18.5 gallons in a Maxima, I don't care what Nissan says.
also I get 360/22mpg all city, changed both o2's and its been great since.
Originally Posted by maxgtr2000
No kidding...check for codes and check the knock sensor, also fuel filter and spark plugs should be check/changed. I usually get 400 to a tank in the city running 93 mostly driving about 60mph. Knoxville/Alcoa TN is a little spread out.
did u see that.. i WISH i could consider doing 60 mph city driving
Originally Posted by l3ftonm3
430 mostly highway driving doing 75. but in city conditions usually 350-360 a tank.
well thats pretty good for city here. usually if i'm in the annoying stop and go traffic here in nyc, i get about 310 or so before my light is on.
How high are you guys accelerating up to getting 400+ miles per tank? I tend to baby it a lot letting it shift at 2000-2500 (auto). Maybe I should test out tomservo291's theory in taking it up a little higher.
Originally Posted by dallas0593
I must have a serious problem somewhere because the most I get is 250 per tank. I have no codes and have changed everything but the plugs.......maybe that's my problem.
Originally Posted by deezo
How do you know how many gallons you have used to make this calculation?
1st tank of gas in my 98 was from Johnson City to Knoxville to London, KY, then back to Knoxville last night. Filled up in Knoxville at 357 and not I am back in London. I am thinking this tank will be better because the first one had a lot of "tests" on it..being a new car and all. Oh, How many other people are on here from Knoxville, TN? maxgtr2000, What part of Knoxville?
Mav
Mav
Originally Posted by JClaw
Revenge of the killer mutant gas mileage thread part MCXVIII. I swear those are like sequels to 80's slasher flicks. They just won't die.
Just say no to drugs and gas threads.
I changed the rear [downstream] because it was throwing a code but not the front 2.
even though they aren't throwing a codeI changed mine out at around 115k (don't remember exactly), but I went from the 15-18 MPG range to 20-22 range
Got mine from the oxygensensor.com group deal (10% off) for $113.xx (Walker OEM)
Originally Posted by JaTaN
That one won't help with MPG since the front ones control the air/fuel ratio. If you have high miles, replace the front ones since yours are probably acting
Hey thanks for the advice JaTaN...I have 152,000 miles and as far as I know they have never been changed, so right after Christmas I will do that.
