key fob
key fob
when bought my max it didnt have the fob for the alarm, so i called up a dealer he told me it's gonna be $120, wtf, so i am wondering if i can by from ebay for example can i repogram it??
me too...
GreenVQ30 -
I am in the same boat. Looking for replacement FOB for my '95 Maxima. The cheapest solution I have found so far is $50 (http://www.keylessride.com/order/quo...&frid=B76BE348) but I am still looking. I did see some on Ebay for half that price but they aren't guarantee to work on older Maximas like mine.
Let me know what you find.
Also, I found this other post on how to program the remote:
To program the remote(s) follow this procedure
1. Close and lock all doors with power door lock switch on driver's door.
2. Insert and remove the key from the ignition more than 6 times within 10 seconds. The hazard warning lamps (both turn signals) will then flash twice and the original codes will be cleared.
3. Turn ignition key to "ACC" position.
4. Push the "Lock" button on the new remote controller once. At this time, the car learns the new ID code. The hazard warning lamps (both turn signals) will then flash twice.
For additional remotes continue below else go to step 9
5. If you need to activate additional remote controllers, manually unlock the driver's door only then lock again with door lock ****.
6. Push lock button on the additional remote controller once.
7. Hazard warning lamps (both turn signals) will then flash twice and additional remote is programmed.
8. For additional remotes, go back to step 5.
9. Open driver's door to exit programming state when done.
NOTE: Only a maximum of 4 remotes can be programmed to any ONE car.
--carguy
--carguy
Yea should be able to. Can't say for sure but here the how to for reprogramming. Can't guarantee these work but someone should be able to confirm it.
1.Get in & lock the doors
2.Insert the key into the ignition 6 times within 15 seconds
3.Hazard lights should flash
4.Put key back into the ignition & turn to Accessory
5.Press the master door lock (on drivers door arm rest) unlock/lock
6.Hit the lock button on the remote
7.Hazards should flash
8.Pull key out and open the drivers door and then close it
9.It should be set
If you have more than one remote, I believe that you repeat step 6 for each remote before performing step 8. However, I have not tried registering more than one remote.
9.It should be set
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
