CV Axle nut
Old Dec 8, 2005 | 07:48 PM
slowalty's Avatar
CV Axle nut
What size is it on a 4th gen?
Old Dec 8, 2005 | 07:49 PM
Kevlo911's Avatar
Kevlo for President
36mm on my remanufactured axle.
Old Dec 8, 2005 | 08:09 PM
JwaxMax99's Avatar
36mm on my original factory axles.
Old Dec 9, 2005 | 04:45 AM
kc10fish's Avatar
spray the axel with lube before you goto pull it out - around the spline area. this is after you get the nut off....good luck
Old Dec 9, 2005 | 06:06 AM
MDeezy's Avatar
I believe its the biggest Nut on the car.
36mm Deep socket is what you'll need.
Old Dec 9, 2005 | 09:44 AM
dgeesaman's Avatar
Maintenance Monster
I think that prize goes to the nut behind the wheel What's a 7-3/4 hat size converted to mm?
(Accidents are always the fault of that nut)
Dave
Old Dec 9, 2005 | 11:11 AM
sonicrunch's Avatar
multiply by .03937
Old Dec 9, 2005 | 03:42 PM
Nealoc187's Avatar
SLOW
Originally Posted by sonicrunch
multiply by .03937
lol
Old Dec 9, 2005 | 05:42 PM
sonicrunch's Avatar
Old Dec 9, 2005 | 07:48 PM
Nealoc187's Avatar
SLOW
So based on the previous few posts you are saying that you multiply the number of inches by .03937 and it will tell me how many millimeters something is?
Old Dec 10, 2005 | 12:00 PM
RA030726's Avatar
I'm nutty for Nissans
most nissans with the #x114.3 bolt patter have 36mm axle nutts and the nissans with #x100 are 32mm
Old Dec 10, 2005 | 03:53 PM
slowalty's Avatar
Well it was a 36 mm like all of you said. I replaced my clutch today with a 5th gen O O O riellys brand clutch. Now i wish i would have went with a ACT or something stiffer. I mean when you press the clutch after it disengages it falls to the floor its so soft. but i wont be replacing the clutch anytime soon again.....Hopefully.
Old Dec 10, 2005 | 03:58 PM
MDeezy's Avatar
Bleed the clutch. Must have air in the lines still
Old Dec 10, 2005 | 04:01 PM
BigLou93SE's Avatar
Hold on, you replaced your clutch with a non-OEM 5th gen. clutch? For future reference, the 5th gen. clutch kits that everyone, including myself, raves about better clamping force is the OEM 5th gen. clutch setup. No one as of yet has reported better performance using a non-OEM 5G clutch.
slowalty's Avatar
Please give me the procedure for doing this. I Have already bleed it twice already. I would pump the clutch then hold it down and then open the valve on the slave cylinder. Then when my friend closed the valve and i let the clutch out it would come back up. I was like wtf. But then we did it a couple more times and it worked, so i dunno.
Old Dec 10, 2005 | 04:04 PM
slowalty's Avatar
Well.......that sucks....I guess im a dumbass.....Has anyone done this before?
Old Dec 10, 2005 | 04:09 PM
MDeezy's Avatar
its not suppost to come back up.
Step clutch, open valve, close valve, he lets off the clutch, and pulls it up with his hands or feet, repeat till you see no air in the lines.
Old Dec 10, 2005 | 04:16 PM
slowalty's Avatar
This is what we did. I might try again tommorw but i think all the air is out of it.
Old Dec 10, 2005 | 04:28 PM
MDeezy's Avatar
DId you use clear tubes to that you can see the fluid that is comming out?
Old Dec 10, 2005 | 06:43 PM
slowalty's Avatar
No , we didnt might try that as well. The clutch is gripping really high.
Old Dec 10, 2005 | 07:04 PM
sonicrunch's Avatar
whoops!
my bad. I got it backwards. I'm so used to converting mm to inches.
make that multiply by 25.4
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
The Wizard
24
Oct 1, 2015 08:47 PM
