Best way to get automatic transmission fluid off cement?
Old Dec 15, 2005 | 05:51 AM
Colossus's Avatar
I got a LOT of transmission fluid on my cement garage floor. It left a stain about 5 feet in diameter.
Here is what I've done so far:
1. Bought some of that kitty litter type absorbent stuff to absorb the moisture.
2. Then I used "Purple Power" Driveway cleaner and scrubbed with a heavy duty push brush.
3. Then I used Kerosene fuel and scrubbed it as well.
I let garage air out over night... there is still a very visible dark stain from the transmission fluid on the ground. (My dad is about to kill me). Any tips on how to get this crap up? Maybe gasoline? Kerosene normally does the trick when I get little oil drops on the ground, but this transmission fluid is really leaving a mark.
Old Dec 15, 2005 | 06:13 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
acid.......... no kidding.. go to Home depot
Old Dec 15, 2005 | 06:38 AM
MaxSE03's Avatar
Yeah, acid is probably going to be your best bet.
You could give this stuff a try though: http://www.properautocare.com/pournrestore.html
(I've never tried it...)
Old Dec 15, 2005 | 06:39 AM
Colossus's Avatar
Yes, I consulted Google and found this:
http://www.howtocleananything.com/ti...s.asp?tid=1123
That TSP might be the stuff you're talking about.
Old Dec 15, 2005 | 07:50 AM
NewLoveI30's Avatar
That sux that it left a stain... When doing my flush I disconnected the wrong side of the return line and pumped out a quart or two all over the garage floor (and my face). I just wiped it up and left it at that. There is no stain today.
Anyway, acid etching is prolly the best way to go if nothing else has worked.
Old Dec 15, 2005 | 08:04 AM
Colossus's Avatar
NewLove,
That's what I did... I think the How-To needs to be updated to specify which line needs to be pulled off. When facing the front of the car, it's the hose on the left (the one on the passenger side) that needs to be pulled off the radiator.
When I disconnected the hose on the driver side, it freaking sprayed at least 2-3 quarts on my garage floor and that's why I've got the stains now. =(
Old Dec 15, 2005 | 09:11 AM
MaximaPolak's Avatar
Put something over it. Maybe a carpet.
Old Dec 15, 2005 | 10:28 AM
Lontar1's Avatar
Originally Posted by Colossus
NewLove,
my How To specify which line to pull......
Old Dec 15, 2005 | 10:34 AM
upstatemax's Avatar
I would not make a big deal about it, it will go away on its own...
If your dad is pissed... use the tried and true method of deflecting blame!
Tell him that if he cared so much, he would have had the floor sealed and this would have never been a problem.
But really, it will go away on its own, dont kill yourself trying to get rid of it. Your dad will cool off and it will go away.
user 11122324
42
Jul 18, 2022 03:35 PM
Need help
23
Oct 2, 2015 08:56 AM
Andy29
Sep 29, 2015 05:32 AM
Pied
Sep 26, 2015 03:29 PM
