Antenna Broken! Motor runs, but antenna doesn't.
Old Dec 16, 2005 | 02:04 PM
cheeyo's Avatar
Anyone successfully fixed their antenna? I hear the motor running when the radio turns on, but the actual antenna doesn't move. Is there an easy way to fix this or is there an easy way to replace the unit? Thanks.
Old Dec 16, 2005 | 02:56 PM
MAXRB8's Avatar
Like many others on the org I went this route:
http://cgi.ebay.com/ebaymotors/Nissa...97773754QQrdZ1
Comes with instructions.
Old Dec 16, 2005 | 04:22 PM
aussie983's Avatar
I bet the the antennas either fallen out of the track or its stripped. You have to look back inside the truck i think near where the jack is to check it out.
Old Dec 16, 2005 | 04:43 PM
DaBlackMaxx's Avatar
dammn man....this same thing happened to me....last week I'm thinkin the car is reeealy dirty (cuz of da snow n salt up here) couldn't see it like that cuz I gotta keep it fresh...lemme run it through da carwash real quick...not even thinkin da radio is on and thought it was one of ma CD'z playin I went through the carwash with the system blastin....I look in my rearview mirror n my antenna is bent ....I bent it back and it even goes up n down, but it doesn't go all the way down and sticks up about 2-3 inchez.....
Thankz MAXRB8....might just do that...might be fixed for like 15$$$....
Old Dec 16, 2005 | 04:46 PM
how hard is it to do this install??....they say minutez but is it that EZ??
Old Dec 16, 2005 | 05:03 PM
MAXRB8's Avatar
It's that EZ, The hardest part is prying out the existing retainer supporting the stock mast this part needs to be reused, don't sweat it the instructions the mast comes with are good. Turn the retainer out using bullnose pliers or something similar like it's threaded even though it's not. You'll see two notches. My new mast even froze in minus degree weather and didn't go all the way down, once it thawed it worked again no probs. They look identical to factory. Cheap!
Old Dec 16, 2005 | 05:15 PM
G4nismo's Avatar
i did it myself in like 20 minutes. nothin to sweat about, you'll be fine
Old Dec 28, 2005 | 10:02 AM
AZMaxima53's Avatar
Well, speaking for those of us who don't do our own work, I'm having the mast assembly replaced right now. Gotta have my radio working, and that sound of rocks grinding that comes from it was getting on my nerves.....
Old Dec 28, 2005 | 10:16 AM
Black Maxima
Make sure the antenna is all the way down. Then unplug the antenna motor. The antenna unit is the most usless piece on the Maxima. The cold always messes it up. The radio reception without it is good enough.
Old Dec 28, 2005 | 10:31 AM
AZMaxima53's Avatar
Not where I am. First, I'm in sunny AZ-- I don't think it's a cold issue. And, AM reception, even on a very powerful station, is full of static. Can't listen to the ball game that way!
FM reception is not bad, except when I go through the tunnel on the way to work.
So, to get the AM reception back, gotta fix it.
I'd rather not have all the power and other special stuff (like the hydraulic hood supports-- I'd settle for a hinged metal rod to prop it up, like my old car had). Too many things to break.
MattWithTheMaxima
Jun 30, 2017 01:06 PM
Finkle
Sep 27, 2015 09:53 PM
BobMax
Aug 15, 2015 12:35 PM
