Car acting wierd...
Car acting wierd...
Ok, today i filled my car up with gas and about 5min later it started studdering. Well when i finally got it home, i thought that maybe it was the fuel filter so i changed it and it still does it. It wont even idle right, you can watch the rpm guage jump up and down, and when you drive it, it does runs really ruff. Also i did have that timing chain rattle for quite some time now, im just wondering if maybe it has finally gone bad or something. I dont know what it could be...Oh yea theres no water in the oil either...Anyone know?
... timing chain... unlikely... bad coil pack is not out of the question but like you said it started right after filling up... so just start by trying some new gas. I've gotten bad gas before. (really stank up the room...)
Two summers past drove my 95 to Colorado. Decided to top off the tank (I use only premium) at a Shell station before going into the mountains. Started noting some missing, and by the time I drove the 40 miles to the condo, I could barely make it up the drive. New fuel filter did not help, so poured in a can of water removing fuel treatment before retiring for the evening. Stumbled a couple of times the next morning when I started it, then cleared up and has not missed since. Water in gas does happen..
Ok, well its still doing it...something i noticed was it doesnt really start acting up until it is warmed up some. You can also get it up to speed and it will run steady, but once you try to give it gas it will start runnin ruff and when you come to a stop it will die most of the time. anyone know what else it could be?
my 86 ford van does this as well...with the studdering and it eventually stalls out. its been sitting on the street for the past 2 years. i wuold like to know if there's any fix. ive done all the obvious stuff, fuel filter, spark plugs, and what not. im really curious as to what is wrong here.
Hello All,
New to the forum. Great sight. I have a '96 Maxima with 165k miles. I have touble starting the car in the cold. Is it time to change the coil packs, or do they last forever? Also, should I think about changing the timing chain?
Many Thanks,
Russell
Many Thanks,
Russell
Ok heard this a million times, my also does this, but my doesn't die. Have replaced everything mentioned above and then some, I am now on to the thought that it could be a vacuum leak. Oh and noone else has ever fixed it.
You better believe the bad gas theory. Its all over the local news how a Valero had water in its tanks. Cars werent starting after a fill up and many cars werent making it far from the gas station. Its very possible that there is water in you tank, escpecially with no prior symptoms and having it occur right after fill up.
Yup...I had the same problem...its the MAF sensor. After I replaced it, it still had some problems with studdering...then I replaced my o2 sensor...car runs fine now. Just go to the "do it yourself" section of this forum and follow the easy steps...u can buy a maf on ebay for around $100 or less...
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
homewrecker
Aug 24, 2015 08:56 PM
