Installed 300zx/Cobra BBK - Questions
Old Dec 17, 2005 | 10:29 PM
Nismo's Avatar
I just finished the install of the 300zx calipers, cobra 13" rotors and SS lines on the front only.
The brake pedal seems to need more travel to get it to stop. When the car is idle or off, the brake pedal is rock solid and the travel is normal distance like stock as it supposed to be but when driving around, the pedal sinks halfway down until it finally gets hard and the car stops great at that point. I want to know what the problem is with the pedal sinking? Theres no leaks and we bled the car several times and there seems to be no more air bubbles in the system.
Old Dec 17, 2005 | 10:44 PM
f550maranello2's Avatar
did u do a good job bleeding the brakes? sometimes it takes like 3-4 times to get all the air out
Old Dec 17, 2005 | 11:24 PM
Nismo's Avatar
We did it about 3 times manually following the sequence and there was no visible air bubbles.
And the squishy sinking pedal only happens when braking when the car is moving. It feels perfectly firm and all that when the car is at idle at a stop
Old Dec 18, 2005 | 01:24 AM
Nismo's Avatar
Ok, I think I might know what happened. When I disconnected the left front brake line to replace it with the SS line, the resovoir all drained out empty. Will that cause my problem eventhough I properly bleed the brakes several times and didnt show any more bubbles?
Old Dec 18, 2005 | 01:34 AM
VIP Maxima
how much did the whole thing cost u, if i may ask?
Old Dec 18, 2005 | 02:49 AM
Nismo's Avatar
I bought it all the parts in a 2 year span so a rough estimate would be probably $600-700
Old Dec 18, 2005 | 08:30 AM
Flava_24/7's Avatar
Boosted Panda
Sounds like you still have air in the system. Id bleed it some more. Did you go from the rear to the front, starting from right rear, left front, left rear, right front?
Old Dec 18, 2005 | 08:37 AM
MaximaSE96's Avatar
Maxima Owner
if he did fronts only he should only have to bleed the fronts...there are check valves that separate F & R lines....but it wouldnt hurt to blee the rears to make sure....any way try to bleed them more and always make sure that the master cylinder has plenty of fluid if u run low u could just be putting more air into the system
Old Dec 18, 2005 | 04:00 PM
Nismo's Avatar
We did all 4 corners in the correct order. I think I just need to keep bleeding them. But if there is air, why does the pedal feel normal when the car is at a stop but gets softer when im braking while moving?
Old Dec 18, 2005 | 04:28 PM
MaximaSE96's Avatar
Maxima Owner
its a whole pressure thing....when ur stopped the pressure can build back up but when ur slowing down ur using all that pressure....trry bleeding them some more...it can take a while depending on how much air actually got in
Old Dec 18, 2005 | 04:34 PM
Jeff92se's Avatar
I'm needing a caw
You might want to bleed the master cylinder if you ran it dry. 1/2 down is WAY too much. I have just a smiggen more travel ie..1/4" maybe?
Old Dec 18, 2005 | 04:35 PM
MaximaSE96's Avatar
Maxima Owner
kwik sort of off topic question i can never remeber if u need put the master cylinder cap on befroe bleeding.....or as long as its full past the check valve can leave it off??
Old Dec 18, 2005 | 04:40 PM
Nismo's Avatar
It drained well over 1/2 down so I guess your right. I have much more travel than 1/4" more like a couple inches
Old Dec 18, 2005 | 05:09 PM
vsamoylov
any pics? does your brake pad sit flush against the rotor? i mean that are you using all of your pad?
Old Dec 18, 2005 | 08:21 PM
Nismo's Avatar
The pads are flush on the rotors and are breaking in against the rotors evenly. Sorry no pics yet. Ive done a Z/cobra install before and it came out good but I think its when I accidentally let the resovoir drain out is the problem and I just didnt bleed it enough
Old Dec 18, 2005 | 08:32 PM
Supermax95's Avatar
my wilwood kit does the same thing. when im moving the top softens up. When i stop its still soft, but when i pump the brake peddle once it becomes hard again.
Old Dec 19, 2005 | 02:15 AM
Nismo's Avatar
How do I go about bleeding the master cyl? Is there a bleeder valve on the MC itself?
PH98I30
Jan 9, 2025 08:08 AM
Quickgtp
Apr 13, 2017 03:30 PM
maxfever1987
Nov 19, 2016 08:01 PM
mikekay
Aug 10, 2015 12:52 PM
