Definate Water pump leak?? (pics)
well it seems that it is the o ring seals on the water pump that went. im going to go buy one tommorow is the oem nissan the best one to get ? I checked all the hoses and they looked fine.
Originally Posted by DcMaN
that is all coolant around the edge of the oil pan. I cant find any other coolant besides that and it drips right down onto the floor from their.
That is probably a bad seal, leaking coolant thorugh the weep hole. Had the same issue last year. Pulled the pump and it was fine, just a bad seal. Replaced the pump anyhow. They are expensive from Nissan, paid around $200 IIRC. Later found that NAPA carries a water pump for our cars for about $100.
-matt
you have any tips for me when removing this water pump ? Im scared about when it says becareful while removing water pump, do not allow water pump to hit the timing chain that **** is scaring me : ( . How close is it to the timing chain. Isnt the water pump driven by it ?
Originally Posted by matty
There only $80-$90 from Nissan. Mine ran $80 from David B at Southpoint. New water pump and seals
-matt
-matt
Maybe my memory serves me wrong, but I could swear it was much more than that. But this has been almost 2yrs ago
This is the write up I used...Its only tricky because the amount of space that there is.
http://forums.maxima.org/showthread.php?t=308680
That definitely looks like coolant collected on that edge. As long as any coolant hoses in that area (if there are any, I don't recall) are dry at the joints, then definitely get a new water pump.
Dave
Dave
Mar 12, 2020 12:06 AM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
Hdnseek
Sep 9, 2015 05:55 AM
@ oil pan pic (both of them).
