Weird Fuel Pressure Readings
Old Dec 29, 2005 | 07:55 AM
BlackCat's Avatar
RIP '98 Maxima SE
Last week I had the time to reinstall the Walbro fuel pump. I'm still using the stock injectors btw. With the stock Vortech fmu still in place my pressure read 32psi @ idle which is the same as stock. I then switched out the recalibration disk and now my pressure is at 40psi @ idle. When I'm doing normal driving I'd see it go to 42psi. After a hwy drive I noticed that the pressure dropped down to 38psi @ idle and then later on back down to 32psi. What's up with that? Starting up first thing in the morning I'd see 40psi.
Now when I reinstalled the Walbro I just reused the original hose clamp instead of the screwdriver/band clamp. Would that be the cause of the problem?
Old Dec 29, 2005 | 09:13 AM
C MAX's Avatar
where are you taking readings, before or after the fmu.
Old Dec 29, 2005 | 10:58 AM
BlackCat's Avatar
RIP '98 Maxima SE
Good question. I can't remember how I positioned the pressure sensor so I'll have to take a look and come back here later.
Old Dec 29, 2005 | 11:58 AM
C MAX's Avatar
you probably have it after the fmu which is the correct place, but you should also test from the walbro itself and see what readings your getting. im not positive but i though it wasnt possible to change the disk on the stock vortech fmu's to run correctly maybe thats the problem.
Old Dec 29, 2005 | 04:55 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
If you have the sender in line, it may give faulty readings. try adjusting it so the fuel has to make a corner.
Old Dec 30, 2005 | 08:29 AM
BlackCat's Avatar
RIP '98 Maxima SE
Ok, thanks! I do plan to take out the Vortech fmu as soon as a free weekend comes up anyways so I'll put up with the weird gauge readings a little while longer. The pressure sensor will be mounted on the Aeromotive fpr.
gustavison
Oct 4, 2015 06:50 PM
aminus21
Sep 12, 2015 04:53 PM
thenewguyy
Sep 12, 2015 11:12 AM
bennuss
Sep 11, 2015 05:55 AM
