VQ30 rods/pistons are SCRAWNY!
Old Jan 2, 2006 | 07:36 PM
TurboS13Hatch's Avatar
You guys are making 500whp on that?! That looks like the same size as a QR25DE rod! The piston has a very thin top ring land too.. I think I'll be building the engine before putting it back together..
Travis
Old Jan 2, 2006 | 09:27 PM
choray911's Avatar
The Crazy Azz Cracka
They're thin but they get it done. A few people have bigger rods in the vq30, but the majic is using the vq35 and the parts made for the 350z.
Choray
Old Jan 2, 2006 | 09:39 PM
SR20DEN's Avatar
VQ Wizard
I'll take "What is rod ratio?" FTW Alex.
Old Jan 2, 2006 | 09:44 PM
desertmaxima's Avatar
Hey I got some custom Arias pistons ill sell yea for the VQ30 very stout and nice.
Old Jan 2, 2006 | 10:12 PM
I was surprised at how small the rods are... the other thing is the small diameter rod bearings.. a smaller bearing is more prone to spin under a big load.. or high RPM. I know the rod/stroke ratio is good.. but still.. the rods are TINY! I guess I could toss in the stock block, and see what it'll hold.. I have a few VQ30's sitting here anyway..
Travis
Old Jan 2, 2006 | 10:14 PM
I've had a TON of problems with Arias.. in the past year, we had 4 sets of pistons with problems due to manufacturing. I've switched to CP.. and haven't looked back. I was trying to avoid building a block.. but if I have to I will do it eventually.
Travis
Old Jan 3, 2006 | 07:43 AM
Fred Allen Burge's Avatar
I always figured that since the power is divided up on 6 pistons/rods instead of 4 that each one sees less load therefore making the skinny rod less of an issue. Is this theory correct? By this thinking then a V8 would be just that much better, even if the displacement was the same.
allen
Old Jan 3, 2006 | 11:59 AM
MardiGrasMax's Avatar
Old Jan 3, 2006 | 12:12 PM
Stephen Max's Avatar
Scrawny rods and thin piston ring lands (relatively speaking) are really only a problem if you have detonation issues. Avoid detonation and you can get away with a lot.
Old Jan 3, 2006 | 12:53 PM
Morfeus17's Avatar
Yeah I was amazed to see they were skinny when I dropped my Upper-Oil Pan. You would think they would bend easily under boost.
Heck, they are still strong considering the size. They almost look Forged a bit.
Nissan sure may durable motors.
Old Jan 3, 2006 | 03:04 PM
vortechpower's Avatar
Its not the size of the rod.. Its how you use it!
Old Jan 3, 2006 | 10:35 PM
subs1000w's Avatar
+1 to that look at all the guys that crack the ford 302 block in half with stock internals its proboly the most common problem once over 500whp mark on a good tune
BigDogJonx
Apr 30, 2017 10:29 PM
A32goldylocks
Sep 14, 2015 06:49 PM
IceY2K1
Oct 21, 2003 04:38 PM
McDisneySoft
Mar 2, 2003 05:45 AM
MardiGrasMax
Jan 15, 2003 05:03 AM
