Consequences of running 3.5 injectors/3.0 ecu
Out of curiosity, what consequences result from running the 3.5's 315cc injectors vs. the stock 3.0 259 cc on the same, completely untuned ECU?
You would definatly run rich like kevlo said. But some people are saying that on the long run, the ECU will accomodate for the larger injectors and "remake" or "readjust" its long term fuel trims (Im not sure if Im using the correct terminology, some1 correct me if Im wrong). How far its able to adjust? Who knows. Get some kind of a/f controller, its fun watchin your WHP/WTQ #s at the dyno go up by just pressing a few buttons
Originally Posted by JClaw
Is it directly proportional?
Originally Posted by 95BLKMAX
I would think it is. At WOT, depending on the rpm/MAF signal, the injectors will hold a pulse for x amount of time. The larger injectors will stay open for the same amount of time, but flow more in that time according to their capacity.
That's what I was fearing. Jesus, it's a nearly 22% difference. I can't believe I ran the car hard all year. Congradulations, I'm a moron.
Who really knows......
I was fearing the same thing with the 5th gen injectors running off my JWT ECU for the 4th gen. When I went to dyno I ended up running fairly lean (13.5:1). It could have been due to the tailpipe sniffer reading leaner than a wideband up stream, but if not that, then I have no idea. Unless the car compensated somehow (not possible?), or the difference between the 259cc injectors and 290cc isn't enough to trip the ECU up.....
Stock cat makes readings leaner IIRC
OT- Where is the best place for a bung for a wideband? In the Y pipe before the cat? In the cat/test pipe?
I assume you mean with a tailpipe sniffer? (I have a test pipe)
In a test pipe would be fine. Near the flex would be perfect.
what could you use to tune vafc2? jwt? both?
JClaw
Are you running the stock 3.0 fpr or no fpr?
Do you know what your fuel pressure is?
The 3.5 injector 315cc rating is for 3.5 bar fp (50.8psi)
The 3.0 injector 259cc rating is for 3.0 bar fp (43.5 psi)
At 3.0 bar, the 3.5 injectors would only flow about 270cc (assuming Bernoulli flow)
You may not be as rich as you think.
Originally Posted by eng92
JClaw
The ecu is gonna get tuned sooner or later, that's a given, but I was thinking of "immitating" the 3.5 ECU by running it 3.5 bar w/returnless, get it tuned accordingly and generally act as if I'm running a full 3.5 swap without VTC's,
the newer ECUs refresh data faster than our vq30 ECUs
people use a/f meters/dataloggers to tune for optimal fuel mix
Don't forget Exhaust Leaks will make you run LEAN as well, so make sure to check for those.
Originally Posted by Nismo3112
My setup:
3.5 w/o VTC's
DE-K FPR
DE-K Injectors
Stock Fuel PSI
Stock pump
3.0 ECU
Any red flags?
3.5 w/o VTC's
DE-K FPR
DE-K Injectors
Stock Fuel PSI
Stock pump
3.0 ECU
Any red flags?
