Fuel injectors, flow rates, fuel system
Old Jan 11, 2006 | 02:18 PM
ewuzh's Avatar
I'm trying to learn more about the fuel system. So there's two ways of increasing the amount of fuel delivered. One is to increase fuel pressure (flow velocity). The other would be to increase the injector size (volume). Following that, would this be a valid fuel system setup for supercharging?
larger injectors (ex: 370cc or 555cc)
AFPR to lower base fp
FMU for increasing fp when boosting
stock fuel pump, no additional in-line pump
The Stillen S/C kit included the in-line pump because the stocker can't provide enough flow at the higher fuel pressure needed when boosting. But if we have larger sized injectors, we don't need as high of fuel pressure because there is more fuel per injector pulse and as a result we wouldn't need an additional/supplemental fuel pump. yay or nay?
Old Jan 11, 2006 | 04:43 PM
subs1000w's Avatar
your right on everything except you need to replace the fuel pump no matter what, the stock pump cant provide enough volume to keep up with the bigger injectors
dont bother with an inline pump just slap a wlbro 255 intank and be done with it
Old Jan 11, 2006 | 08:26 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
yay. PM me if you have more questions. Mike and I both have done a lot of research on this. Check the stickies for some sites with formulas.
Old Jan 12, 2006 | 07:56 AM
iansw's Avatar
I've gone through 2 Walbro Fuel Pumps - both within 1 week of installing.
If it wasn't for that inline pump I would have never made it home.
I say install the inline pump but have it switched off until one day you need it.
Old Jan 12, 2006 | 10:20 AM
ewuzh's Avatar
That doesn't sound good. I just got my walbro in the mail.
So the inline pump by itself can pump enough juice for running the engine, I'm guessing below 3000rpm?
Old Jan 12, 2006 | 11:37 AM
SPiG's Avatar
SomePsychoGuy
Hard wire your walbro. I have heard that really helps its shelf life and helps it flow better since the stock puny gauge wiring can't get enough power to it.
Old Jan 12, 2006 | 11:59 AM
iansw's Avatar
THe Inline pump by itself flows enough and is a high enough duty cycle that I've run without the inline pump working at all and it's been fine through my raised redline.
Old Jan 12, 2006 | 12:57 PM
I30tMikeD's Avatar
I have mine hard wired.
You can by a simple kit for cheap to do it at www.DeatschWerks.com
Old Jan 12, 2006 | 01:16 PM
ewuzh's Avatar
Hard wired meaning wired directly from the battery with some kind of relay in between hooked up to the ignition ON power?
Old Jan 12, 2006 | 02:46 PM
I30tMikeD's Avatar
yep, that's it
Old Jan 13, 2006 | 07:39 AM
Fred Allen Burge's Avatar
[QUOTE=ewuzh]I'm trying to learn more about the fuel system. So there's two ways of increasing the amount of fuel delivered. One is to increase fuel pressure (flow velocity). The other would be to increase the injector size (volume). Following that, would this be a valid fuel system setup for supercharging?
/QUOTE]
You forgot the 3rd way of increasing fuel, increasing the injectors pulse width (making it stay open longer).
Also, what's the point of adding larger injectors if you are just going to lower the fuel pressure? Lowering the fuel pressure negates the larger CC injectors.
And, if you are going to use an FMU you will want an upgraded pump to keep up with the additional fuel pressure the FMU will create (the pump has to work a lot harder when the FMU raises the pressure to 70, 80, or more psi).
And finally, in my humble opinion if you are under 10 psi just run the FMU and upgraded fuel pump, skip the adjustable FPR and the larger injectors.
allen
Old Jan 13, 2006 | 08:12 AM
I30tMikeD's Avatar
allen
You are not going to lower base fuel pressure enough to negate larger injectors. Yes, it will cause them to flow less but it doesn't negate them. That is if your running 370's or larger. The idea of lowering base fuel pressure is for those who do not have the fuel management to control them at start up or idle. A AFPR is needed for a set up like 370's, Z32 MAF, and an FMU or SAFC
Sock injectors, an FMU, and upgraded fuel pump will work fine for lower boost levels...but pusing 8,9,10 psi is just too much for an FMU and stock injectors. A turbo VQ30 can make 350whp on 10psi. You would need to run something crazy like 130psi of fuel pressue to get enough fuel to do that. I used that set up when I was first turbo and had to run 95psi of fuel pressure to keep a decent AFR at 250whp
Old Jan 13, 2006 | 10:07 AM
ewuzh's Avatar
Well I guess my question should have been:
For lower boost levels, is there a way to run only the stock fuel pump? Either with a combination of larger injectors and/or AFPR and/or ECU program.
Old Jan 13, 2006 | 11:17 AM
I30tMikeD's Avatar
No, do not run the stock fuel pump. You can get a walbro new for less than $100. It is just silly not to get one.
Old Jan 13, 2006 | 11:23 AM
subs1000w's Avatar
maybe but i wouldnt risk it
ive never met anyone that had a bad thing to say about a walbro pump and i know alot of people running them i have a 255 in both my max and f150 and have had no problems
Old Jan 13, 2006 | 12:44 PM
JdoubleOe703's Avatar
teddibear703
just wondering, for the 370cc injectors, which ones are they( brand, years)? I see something about 300zx and the sr20det engine ones , but still am unsure. also can i mix and match or is it preferred to all be the same( example 4 from sr20det and 2 from 300zx)? I dont know anything about injectors...
Old Jan 13, 2006 | 12:55 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
These guys are talking about 4th gen injectors...our 5th gens use different injectors.
If you're looking for a set of 380cc for your 5th gen...check my thread out: http://forums.maxima.org/showthread.php?t=444605.
Old Jan 13, 2006 | 06:29 PM
teddibear703
i c... so for 5th gen's what are our options? is it only the 380cc ones?
Old Jan 13, 2006 | 08:55 PM
IceY2K1's Avatar
Plug-N-Play, ie no cut-n-splice or spacers:
Power Enterprise 380cc/510cc ~$830 retail
Nismo 480cc ~$700 retail
Deatchworks rebore OEM injectors
Cut-n-Splice w/spacers:
Bosch
RC Engineering 370cc-600cc or so $550+
BkGreen97
Apr 2, 2016 05:47 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
gustavison
Oct 4, 2015 06:50 PM
RWCreative
Sep 21, 2015 11:01 AM
