Abbreviations Terms
Old Jan 16, 2006 | 09:12 AM
5thgenmaxima's Avatar
Abbreviations Terms
I've been reading a few articles and noticed some people throwing around terms incorrectly. I thought I would make a quick post.
PCV = Positive Crankcase ventilitation
EGR = Exhaust Gas Recirculation
H02S = Heated 02 Sensor
PCM = Powertrain Contol Module (Integerated TCM and ECM)
TCM = Transmission Control Module
ECM = Engine COntrol Module
ECU = Electronic control unit
TPS = Throttle Position Sensor
ECT = Engine Coolant Temp
IAT = Intake air temp
MAF = Mass air Flow
BCM = Body Control Module (Also known as smart entrance control unit on Nissans)
MAP = Manifold absolute pressure (Also known as vacuum)
KS = Knock Sensor
OBD II= On board Diagnostics second generation(96 and later automobiles)
OBD = On board diagnostics
CKS = Crankshaft position sensor
CPS = Camshaft position sensor (Alot of technicians refer to cps to crankshaft position sensor - This was CKS term before OHC)
Feel free to add or edit any of the information.
Old Jan 16, 2006 | 09:14 AM
jjs's Avatar
jjs
ECU=http://autorepair.about.com/cs/generalinfo/l/bldef_160.htm
Old Jan 16, 2006 | 09:22 AM
Intresting...So the ECU is basically another term for PCM....Guess I have taken from the incorrect knowledge on this board myself. ...
I wonder if the ECU is the "electronic control unit" then how can alldata list a ECM???
I have edited my first post
Old Jan 16, 2006 | 03:07 PM
paralyse's Avatar
I Miss My Maxima
ECM/ECU are the more common terms for what Chrysler calls a PCM or Powertrain Control Module. Chrysler's PCM is a bit misleading since it controls many things other than the engine and transmission.
jmlee44
Oct 2, 2022 02:13 PM
Mar 12, 2020 12:06 AM
MaxLvr21
Oct 17, 2015 12:11 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
