New Live Edit
Old Jan 16, 2006 | 10:14 AM
Bernardd's Avatar
New Live Edit
www.romeditor.com
Old Jan 16, 2006 | 12:46 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
still no love for 4th gens.
Old Jan 16, 2006 | 04:01 PM
maxmaxima91's Avatar
hm.... this makes me happy
Old Jan 16, 2006 | 07:36 PM
mtcookson's Avatar
1350 for the newer romulator....
i'm waiting for someone to come out with an auto-tuning ecu using a wideband o2 sensor. i think someone is actually working one over in the mr2 spyder forums.
Old Jan 17, 2006 | 08:29 AM
Bernardd's Avatar
Mark, do you have any links to the mr stuff? I have a buddy who's looking into that ecu.
Old Jan 17, 2006 | 09:25 AM
mtcookson's Avatar
I beileve this is the link http://www.spyderchat.com/phpBB/view...ght=tuning+ecu
Old Jan 17, 2006 | 06:06 PM
Boosted Maxima's Avatar
Cool Info... Thanks!!!!!!!!
Scott!!
Old Jan 18, 2006 | 06:18 AM
Fred Allen Burge's Avatar
Megasquirt and Megasquirt II have auto tuning software using a WB (or even a narrow band only for low speed areas of the map).
My whole setup has totalled about $500.
www.megasquirt.info/ms2
allen
Old Jan 18, 2006 | 06:23 AM
Here's a section of the megasquirt tuning manual:
You can also use auto-tune to help tune your VE table.
Auto-tune is an algorithm built into recent releases of MegaTune that automatically tunes your VE table based on EGO feedback. It is similar to MSTweak3000, but operates in real-time, without a datalog, and on any variant of code and processor, including MegaSquiirt-II, that uses MegaTune.
With a narrow band sensor, you can use auto-tune with any algorithm and any sensor to tune the low-power part of the table, it will get you to stoich (or AFR targets) quite nicely, which will give you a starting point from which to extrapolate the high-power part.
You don't need a dynomometer to get the high output regions of the VE table done, but you definitely should NOT use auto-tune with a narrow band sensor for that part of the table, you'll end up with broken or melted pistons. In order to use auto-tune for WOT tuning, you must be running a wide band lambda system (sensor and controller), with appropriate AFR targets in the AFR table. If one of these requirements is missing, then you must rely on seat-of-the-pants and experience.
allen
Old Jan 18, 2006 | 08:57 AM
mtcookson's Avatar
That magasquirt really seems to be a good way to go. I'll likely be trying it out on my VH45 280Z project.
Old Jan 18, 2006 | 10:21 AM
Ya, it's pretty impressive really. I'll post up my setup once I get it installed and running. Should be running in a few weeks.
allen
Old Jan 18, 2006 | 10:29 AM
Just noticed you're in Kansas, Howard's not too far from Joplin.
allen
Old Jan 19, 2006 | 07:06 AM
mtcookson's Avatar
yeah, i've been through joplin a few times before. seems like a pretty nice place. are they any local meets around there? i've been to branson z fest before and will likely go again but that's the only one in missouri i've been to.
i read a thread over on hybridz and someone was saying that the megasquirt basically doesn't support cop ignition. you guys know if this is true?
if so, i might have to change around what i'm going to do with the vh45 and use the romulator or change the ignition around.
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
Redfox
Sep 28, 2015 10:41 AM
Domf3
Sep 22, 2015 03:05 PM
