What's the most beneficial A/F ratio?
I dyno tuned today, got 204.56 WHP 210.03 WTQ, '97 Auto with VQ35, numbers are uncorrected, correected they are 199.xx WHP, 205.xx WTQ. My A/F ratio seems to be between 12.2-12.5 a hair below 13, I got the files e mailed to me but need the software to upload the files. I'm asking about the A/F R. because after driving 150 miles or so I got a code, 0210, left bank fuel inj system: lean.
Overly so. 12.0-12.5 is too rich (not unsafe, but pointlessly rich).
Timing is where the power is at really. AFR will affect your power a little bit, but you probably wont gain more than 5hp or so going from 12.5-13.5.
No, that is a good example of what a VQ35 puts down with sh*tty timing. VTC's are worthless above 4000 rpms.
With that said, isn't that pretty much what a stock 2k2 auto dynos, no? Do you have any mods?
Can we see the runfile? This would be the first time we actually see the dyno curve of a 4.5 gen *drumroll*
Check this thread in the Z forums. Highest N/A HP has been obtained with a 12.0-12.3 a/f from 3k upward.
http://www.my350z.com/forum/showthre...=165068&page=2
Last year I ran most of the season with a 12.5 N/A.
Holy ***** 313whp even if that's inflated it is utterly amazing. That guy may actually be putting down 290whp or so with STOCK CAMS. Can you imagine that in your 2600 lb GXE, Jim? Hello 110 mph traps.
So 12.5 it is then.
So 12.5 it is then.
Originally Posted by Jime
Read the whole thread, thats what its all about, good reading.
But definitivley, many opinions can be made etc, but unless it was done on a DJ, then that would be the deciding factor.
Also, the shape of the curve is important, and I'm surprised he's still at 6500 rev limit still.
I read that thread in the Z forums a few days ago.. it was impressive, until I realized it wasn't a dynojet. Wonder what it would be on a dj.
As far as A/F goes, I honestly don't think it makes much difference from above 12.5 up to 13.5. Any time I've been tuning on a dynojet, I saw little change in power past higher than 12.8 so I set mine 13.0 to 13.2 on average as a compromise between fuel economy and knock resistance. Mind you, that's on a VQ30 not a VQ35 but others who have tuned a VQ35 seem to think 13.0 to 13.5 is best (SR20DEN for example, on a Mustang dyno which is better than a dynojet for tuning).
Originally Posted by HarrisH
The higher the number for the AFR the leaner?
I don't think my last run was included I will have to scan it. That was 210.xx WTQ, 204.xx WHP UNCORRECTED. A/F Ratio was between 12.0-13.0.
Originally Posted by Kevlo911
Hmmm, I need headers and a Pathy TB and I might start catching up to you
Looking at that dyno, it seems like timing is the one to point the finger at. And worst is, it's impossible to predict how much of a different it would/will make.
Ooooh this is killing me. We just had another giant snowstorm. Winter shows no sign of letting up. Three months down, three to go.
Ahh, I see. I thought the VTC's added power in the upper RPM's (like VTEC). I take it the stock cams are basically high HP/RPM cams and the VTC's just change the timing to bump the low RPM power up for better drivability then, right?
allen
So the highest power it made was 199.xx and 204.xx CORRECTED A/F Ratio was between 12 and 13.
Anyone care to comment on my 0210 code which is for running lean?
I don't see your A/F ever going higher than 12.6 or so. Maybe bump it up into the low 13's and see how the curves change. Keep in mind your variations in power are likely timing related as well, since tuning with an SAFC/VAFC (don't remember what you have) will indirectly affect timing.
My comments on not seeing a difference in power due to A/F fluctuations between med-high 12's up to 13.5 are based on changing fuel only, not timing, which I can control independently with the EU. You may get slightly different results since you are changing timing when you change fuel via MAF conditioning.
allen
allen
Originally Posted by TILLEYS99
Harris your car is still slow. We should put it up against my black car.....
Are all the injectors good? Are they all connected? Any misfire? That might be why it is throwing a lean code.
Are ALL the ports lined up for the 00vi? If not, you might have an air leak causing it to run lean and losing alot of power.
All injectors are good as far as I know, no misfire codes, 00VI has been on for months, first time I'm getting this code, hopefully it's just a glitch.
Oh I see.
Re-dyno tune the car and make the AF FLAT at 13.0 from 3000+(or 3500+)
Oh I see.
Only if I had the cash to blow on this car.
Speak for yourself...
