02 Max won't start - security light on.. HELP!!
Old Jan 25, 2006 | 07:05 AM
ikalinin's Avatar
my brother has a 2002 maxima and recently he's been having problems starting it. Sometimes when he puts the key in, and turn it to the ACC position, the security light by the clock goes on solid. This way, the car only cranks and does not start. Sometimes the light doesn't go on, and everything is fine.. has anyone experianced anything like this and what did you do to fix it?
please let me know, i'm looking for replies ASAP.
thank you all.
Old Jan 25, 2006 | 07:38 AM
igzy's Avatar
I Know Kwaliti
Sound like an intermittent problem with either the key or the ECM (I think that's where the security settings reside)... Does he have the same problem with his spare key?
Old Jan 25, 2006 | 08:01 AM
ikalinin's Avatar
car was bought used, and he only has one key. The problem is intermittent, yes.
I don't think its the ECM.. although I could be wrong. I just think it would be more often if it was computer related..
He took it into the guy he bought it from (dealer) it has been starting fine the past 2 days... Any other thoughts ppl?
Old Jan 25, 2006 | 08:18 AM
gold007eye's Avatar
New to the Maxi world...
I would have to go with the problem being the key (programming). Maybe it needs to be reprogrammed with the ECU.. Try getting another key and having it reprogrammed. I had some keys cut and it would go into ACC posistion but wouldn't crank until programmed.
If you are going to get a new key I would suggest saving some $$$ and getting the blanks on ebay. Nissan charged $104 for 1 key & programming. I bought 4 keys off ebay for like $30 or so.. programming at dealership (were I went anyways) was $40 for as many keys as you had.
*When getting keys programmed you need to get the original to, because they all have to be programmed at the same time.
Old Jan 25, 2006 | 09:51 AM
boondoxmax's Avatar
Does he have any programmable devices attach to his keys like a mobil speed pass or fast lane for the tolls. They will cause the car not to start sometimes. I had that happen to me on my 02 max and I took the speed pass off and it stopped. Check that first
Old Jan 25, 2006 | 11:28 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Dealer man.. take it there so they can diagnose the problem with the Key....
Old Jan 25, 2006 | 03:16 PM
HotshotVQ35's Avatar
what happenend to the other two keys?
Old Jan 25, 2006 | 03:25 PM
djsoniq's Avatar
I doubt a speedpass could be causing it, those are passive devices that are not read by anything in the car.
Old Jan 25, 2006 | 04:44 PM
boondoxmax's Avatar
Yes it can. There was a TSB out by nissan for vehicle not starting and one of the causes was mobil speed pass.
Here is the TSB
http://maxima.theowensfamily.com/tsb/NTB99-063c.pdf
Old Jan 25, 2006 | 07:19 PM
maxpwr2k1's Avatar
hmm does he use the key fob to unlock the doors...there is possibility that its not completely disengaging the security system which prevents the car from starting properly...this can be due a drained fob battery...ive had this exact problem in my g20 and that was the cause
Old Jan 29, 2009 | 06:53 AM
JiggaD369's Avatar
Hi guys. Sorry to bring this thread from the graveyard but I'm having this same problem and I need to get the car to the dealer. However, I can't get it to start. Was anyone ever able to figure this problem out?
Old Jan 29, 2009 | 08:00 AM
Progress's Avatar
It's business time.
I had a problem starting my car and it turned out to be a faulty immobilizer. It was a pretty quick fix at the dealer.
Do you have AAA so you can tow it?
Old Jan 29, 2009 | 08:29 AM
o0zarkawater2's Avatar
If you can't get it started and need it towed, most people don't always think about if they have Road Side assistance on their insurance, or on their phone plan. Sprint has a roadside assistance program that if you are subscribed to, you could get it towed for free through that.
kjlouis
Nov 24, 2018 06:09 AM
trasmadean
Jan 20, 2018 05:05 AM
02PearlSE
Oct 7, 2015 02:12 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
BobMax
Aug 15, 2015 12:35 PM
