View Poll Results: did u change ur strut mounts...?
yes
33.33%
no
66.67%
Voters: 9. You may not vote on this poll
strut mount replacement...
Old Jan 25, 2006 | 01:23 PM
KabirUTA13's Avatar
IN IRAQ MAXIMA.ORG-ING :)
how many people replaced their mounts during the time of changing the struts springs etc...
Old Jan 25, 2006 | 01:29 PM
Progress's Avatar
It's business time.
I've heard that only if your car makes noises when turning you don't have to replace them.
Old Jan 25, 2006 | 01:31 PM
KabirUTA13's Avatar
well im running stocks rite now... im waitin for my h&r's to come in so i can install them with my illuminas... in that spur of the moment while things are apart... would u replace em as chances are they cood be worn out or jus for the hell of it i dunno,,,
Old Jan 25, 2006 | 01:33 PM
KabirUTA13's Avatar
im jus tryin to generate some type or response from people if they've done it or not just to see if its really worth that 150 dollars for the KYB Strut & Shock Mount Front and Rear fitment
Old Jan 25, 2006 | 01:35 PM
Progress's Avatar
It's business time.
I'm getting illuminas/h-techs installed in two weeks. Unless they look like they need replacing, I will not replace them. After the installation I will vote.
Old Jan 25, 2006 | 01:45 PM
KabirUTA13's Avatar
ok sounds good...
Old Jan 25, 2006 | 01:55 PM
spdfreak's Avatar
How often.............
How often do you have to change them?
(In terms of miles.)
Old Jan 25, 2006 | 01:57 PM
KabirUTA13's Avatar
i'd def like to know that as well... im running into 94k rite now...
Old Jan 25, 2006 | 02:01 PM
2K3MAX2NV's Avatar
"tse-tse fly"
cost me $100 for Nissan OEM parts that was 10k ago so far so good
Old Jan 25, 2006 | 02:05 PM
spdfreak's Avatar
I'm running @ 60,000 and when I change my springs, shocks, I would like to know if its necessary.
Old Jan 25, 2006 | 06:37 PM
Warik's Avatar
Thanks for the poll Kabir...
This item came up in my other thread and I'd like to hear an answer too.
I don't know how to tell if the mounts, boots, and bumpers "look" like they need to be replaced... and even if I did, I wouldn't know until I've got them off the car and then I'd need to order 'em and then take the car apart again... I'd rather not do that.
Is there some sort of guideline on how long the factory mounts, etc... should last? Will the car handle "better" with new mounts/boots/bumpers (particularly these) even if they DON'T need to be replaced?
Old Jan 25, 2006 | 08:06 PM
rbrown81's Avatar
But why is teh Rum gone?
FTW!
Old Jan 26, 2006 | 05:52 AM
Spin20's Avatar
I changed my stock to tein h-tech and illuminas and I used the same strut mount. I have had no problems (but I only have 43k on the car) I dont see a problem with changing it especailly if you have the extra $ for it. It will save you from having to do it at a later date.
Old Jan 26, 2006 | 10:19 AM
Warik's Avatar
Just a note that the KYB strut mounts/bumpers/boots from TireRack DO NOT include the bumpers & boots for 5th gen Maximas. I called to make sure and they said that even though the picture shows it, they only come with the mounts. Talk about misleading advertising. Glad I didn't order them.
Is there any way to determine whether or not my mounts, boots, and bumpers NEED to be replaced BEFORE I take the wheel and struts/springs off? The mechanic who checked out my car and said I needed to replace my front struts said that I "should" also replace my strut mounts, but I don't know if he was just trying to jerk me for more $$$.
Old Jan 26, 2006 | 10:28 AM
Progress's Avatar
It's business time.
I've heard, and I posted this before, that if you don't hear an unusual noise when turning (try it lock to lock at low or no speed) then you should be ok.
D Mason
Jun 21, 2016 04:43 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
knight_yyz
Nov 1, 2015 01:34 PM
