Has anyone used Det cans for tuning?
Old Jan 26, 2006 | 09:07 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
Interested in buying the device but no luck searching on Google... only came up with a few relevant results:
http://www.google.com/search?hl=en&q=det+cans
Do anyone know where to get it? Not interested in the Snap On version because it's too bling for me (couldn't find it on their site anyway).
Old Jan 26, 2006 | 05:50 PM
Y2KevSE's Avatar
No one interested in listening for knock that devices can't pick up?
Old Jan 26, 2006 | 05:55 PM
mtcookson's Avatar
is it basically a high quality knock "sensor"? i've not actually heard of a det can myself.
Old Jan 26, 2006 | 05:58 PM
Nealoc187's Avatar
SLOW
Never even heard of it.
Old Jan 27, 2006 | 10:48 AM
Y2KevSE's Avatar
Knock sensing devices do not pick up knock all the time, or cannot process it as fast as a human can. The device has to listen to close to the correct frequency to actually pick up knock, which changes with mods especially adding a turbo to an N/A car. Even high quality knock sensors might be "off."
I've used Det cans at local tuning shops to listen to knock while the car is being dynoed, but I want to purchase one because I often road tune the car. I have a device that logs knock voltage but it's hard to watch the road while looking at the laptop for voltage spikes. With Det cans, I can quickly let off the throttle if my piggyback doesn't retard timing quick enough.
Doing 25-26 psi (stock is 20.5) and advanced timing leaves little room for mistake(s) while tuning.
Old Jan 27, 2006 | 10:59 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
You could use a PLX R500 to listen for knock.....
Old Jan 27, 2006 | 02:55 PM
Y2KevSE's Avatar
I'm already using the LM-1 with RPM convertor to log knock voltage and I will soon have the ECU+ hooked up, which also logs knock voltage and timing.
Old Jan 27, 2006 | 03:43 PM
IceY2K1's Avatar
The R500 has an audio jack, so you can wear headphones while you tune.
Old Jan 27, 2006 | 05:15 PM
Y2KevSE's Avatar
Same with the LM-1's RPM converter.
Old Jan 27, 2006 | 05:22 PM
Y2KevSE's Avatar
My bad, it doesn't. The audio jack is for something else.
Old Jan 27, 2006 | 05:24 PM
IceY2K1's Avatar
Que?????????
Old Jan 27, 2006 | 05:25 PM
IceY2K1's Avatar
The funny thing is the R500 knock features seem to really only work well on the EVO.....
Old Jan 27, 2006 | 08:03 PM
Y2KevSE's Avatar
The audio jack is for the inductive clamp (RPM signal).
There are lots of devices that work well for the Evo. Many of the logging devices/piggbacks don't have the ability to take enough samples of knock per second.
Roymg
Sep 3, 2018 05:10 AM
Finkle
Sep 27, 2015 09:53 PM
BobMax
Aug 21, 2015 07:38 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Flores94
Aug 13, 2015 01:17 PM
