What can I do get get a lil more bass?
Old Jan 26, 2006 | 07:50 PM
MAXIE06SE's Avatar
I want to keep the BOSE ( SOUNDS GREAT ) But i just want some more boom, that sounds NICE!
maybe a bazooka?
Old Jan 26, 2006 | 08:04 PM
slickrick's Avatar
negative on the bazooka and bose...get rid of bose for more bass.
Old Jan 26, 2006 | 08:08 PM
MAXIE06SE's Avatar
I like the bose ALOT... Perfect high's .. just want more bass, no one has an idea?
Old Jan 26, 2006 | 08:12 PM
nismos14's Avatar
§è~® f®ÈÄk
Basslink .
kpr10is's Avatar
LOL
You just said perfect highs and Bose in the same sentence.
TXT-1's Avatar
http://www.crutchfield.com/S-Ei3zUBs...k&i=108BASSLN2
Old Jan 26, 2006 | 08:15 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Perfect highs/sounds GREAT???
Ummm no comment here.
Old Jan 26, 2006 | 08:29 PM
MAXIE06SE's Avatar
Thanks fot the replys has anyone install the Basslink sub in the car?
What do I need to do? run a power wire, ground.. and the split the bass from the "subs" that are in the car now?
Old Jan 26, 2006 | 09:38 PM
djfrestyl's Avatar
Suspension Yoda
Run a power, ground, remote turn on.
You can splice the signal off the Bose.
See if the basslink has high level inputs along with the low (RCA) that comes standard. That will determine what signal you are taking off the Bose sub
Old Jan 26, 2006 | 09:52 PM
AscendantMax's Avatar
the basslink has both high and low level inputs iirc.
Old Jan 26, 2006 | 10:41 PM
MAXIE06SE's Avatar
So where would be the best part?
I really don't want to "cut" anything and void the warrenty
Old Jan 27, 2006 | 01:16 AM
BK1's Avatar
BK1
Hello
I got the kenwood model. I don't want a massive box because I use the trunk for my bikes in the summer. Dahons.
Old Jan 27, 2006 | 05:28 AM
ShowMe's Avatar
I added a 12" sub in a custom encloser to my BOSE.....I will take pics when I get home.....
Old Jan 27, 2006 | 09:51 AM
MAXIE06SE's Avatar
Cool thanks, how did you install it?
Old Jan 27, 2006 | 10:36 AM
KyMan's Avatar
You could sound deaden your doors (look in the stickys for the how-to). It is supposed to give you clearer bass and of course insulate your car from road noise. I haven't dont it yet (soon my friends-when I get the sub), but many of the guys on here have. Maybe one of them will pipe up on their observations.
Old Jan 27, 2006 | 10:38 AM
Apollos2's Avatar
IMO the stock Bose system kicks. Best stock system I ever owned anyway.
More bass: A stereo shop can add an amp and sub box for you. (Spliced into the existing Bose system). That's more than a little bass though and can get pricey.
A little more bass: I dramatically improved my 05 SE system by having a shop add some sound deading to the front speakers, and the rear deck subs. I will go back soon to have them add some to the rear speakers too. And it didn't even cost a lot.
Here's the thread:
http://forums.maxima.org/showthread.php?t=439367
Old Jan 27, 2006 | 10:57 AM
MAXIE06SE's Avatar
I got a price for Basslink II , installed with wireless and all for $465.00
But I want to know how to tell them to install it would out ****ing up the bose system
Old Jan 27, 2006 | 11:45 AM
djfrestyl's Avatar
Suspension Yoda
they can TAP, not cut the low level inputs at the bose sub
Old Jan 27, 2006 | 11:50 AM
MAXIE06SE's Avatar
Where would that be located?? Thank you VERY much for everyones help
Old Jan 27, 2006 | 01:31 PM
djfrestyl's Avatar
Suspension Yoda
At the sub.
Look in your trunk, then look up.
Someone please chime in with the wire colors, I don't have that information offhand.
Old Jan 27, 2006 | 03:21 PM
kpr10is's Avatar
There will only be 4 wires at the Bose sub, power, ground, positive speaker, and negative speaker. Youll tap into the LOC there and it wont really matter as far as colors because youll tap both positives of the LOC into one speaker wire and both negatives into the other. Keeping the rest of the system stock, its not gonna matter, the LOCs inputs will still be in phase.
Old Jan 27, 2006 | 03:42 PM
MAXIE06SE's Avatar
What does LOC Stand for and where is it located?
Sorry if i sound stupid..
Old Jan 27, 2006 | 03:43 PM
kpr10is's Avatar
Why don't you leave it to the professionals? Just curious.
Line Output Converter. It takes factory speaker and converts it to RCA.
Old Jan 27, 2006 | 03:46 PM
MAXIE06SE's Avatar
Anyone have pictures also???
I have done amps and subs before, just not with bose.
Old Jan 27, 2006 | 04:37 PM
kpr10is's Avatar
No you havent. You may have looked, but not installed.
Come on man...Where is the Bose sub? Be honest, don't try to act like you know what your doing, youll get owned that way.
Old Jan 27, 2006 | 05:10 PM
play nice now
Old Jan 27, 2006 | 05:20 PM
MAXIE06SE's Avatar
I know where the bose sub it.... but where is the amp's to it, does it have pre outs?
Old Jan 27, 2006 | 08:25 PM
Apollos2's Avatar
If your shop doesn't know how to install this without you telling them how, it might be time to look for another shop. The place the installed my MTX amp and sub box new exactly what to do. Tapped into the existing system and it was done.
Old Jan 27, 2006 | 09:13 PM
kpr10is's Avatar
Best post of the thread
Old Jan 27, 2006 | 09:25 PM
MAXIE06SE's Avatar
They said there going to go from my subs to a HILO CONVERTOR ...
But it seems like it is a different and better way, so from my understand there is an amp for the subs they should going from....? correct?
Thanks for everyone's help.
Old Jan 28, 2006 | 06:33 AM
BK1's Avatar
BK1
Hello
This is true.
Old Jan 28, 2006 | 06:55 AM
NismoMax80's Avatar
SuPeRmOd
If you're asking where the AMP is located, then you clearly do not know where the BOSE subS are located.
If you don't want to cut anything or tap you can access RCAs in the dash with PAC OEM1 Bose adaptor:
http://forums.maxima.org/showthread....1+Bose+adaptor
You WILL have to make a hole somewhere to power your amp. Warranty can only be voided if you damage something, not by installing something.
Old Jan 28, 2006 | 08:35 AM
slickrick's Avatar
I would take $300 of that and make a better sounding system...
Old Jan 28, 2006 | 03:35 PM
BRINKLEY's Avatar
yeah, I wouldn't pay that much, and I sure as hell wouldn't keep the Bose hooked up. You may like it and it may be the best stock system you have ever had, but trust me, unhook it and get a good system. The Bose system sucks.
Old Jan 28, 2006 | 05:45 PM
ShowMe's Avatar
well here is my setup....a single 12" with an alpine amp pushing it
Old Jan 28, 2006 | 07:18 PM
MAXIE06SE's Avatar
Cool, How did u do it? Tap inthe the bose amp?
Old Jan 28, 2006 | 10:43 PM
ratha77's Avatar
I have done this I have an 03, installed the amp, like normal, tapped into the sub wires just as kpr10si said, used a hi low converter from stinger, ran the rca wires to the amp, speaker wires to 1 12" Infinity sub in my trunk, all while keeping my stock BOSE HU, speakers ect, eventually I will swap all that out, but fo now it sounds awsome man, do it that way bro, it works well IMO
Mar 12, 2020 12:06 AM
vybz05
Dec 10, 2015 07:38 PM
popdedop
Sep 11, 2015 11:17 AM
MatthewsMaxima
Sep 11, 2015 03:21 AM
