Compression check
Old Jan 27, 2006 | 12:47 PM
I30tMikeD's Avatar
Compression check
Been turbo for about a year now so I figured it was long past due on a compression check. This was a salvage motor I got about two years ago with 79K miles. Has about 105K or so on it now. I have had detonation here and there and have certianly pushed the motor to it's limit on stock timing.
I did all cylinders twice
Cylinder 1: 195 & 195
Cylinder 2: 209 & 210
Cylinder 3: 198 & 200
Cylinder 4: 205 & 205
Cylinder 5: 210 & 210
Cylinder 6: 200 & 202
Good results. Nothing to worry about. A little high but I am pleased
Old Jan 27, 2006 | 01:45 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
What method did you use?
Throttle held open?
Just one plug removed or all?
Cold or warm?
Just wondering, since I need to check mine and I've tried on a different car with varying results depending on above.
Old Jan 27, 2006 | 02:57 PM
I30tMikeD's Avatar
Throttle held open?
Cold or warm?
Throttle open
all plugs removed
Fairly warm. Test was done after car sat for 1/2 hour but it was driven for an hour before that
Old Jan 27, 2006 | 06:57 PM
Chief Brody's Avatar
Looks like you are really taking care of it. Nice job.
Old Feb 1, 2006 | 04:46 PM
jac121479's Avatar
MikeD
what would cause your numbers to be high. low i could understand. aren't VQ's suppose to be around 175?
Old Feb 1, 2006 | 04:56 PM
DandyMax's Avatar
3.5 in the works
Carbon build up will cause higher compression than stock...
Old Feb 1, 2006 | 04:59 PM
MDeezy's Avatar
Good numbers mikeD, definately nothing to be worried about.
Originally Posted by jac121479
MikeD
I believe 180 is the average number. I believe a lot of carbon deposite can give a higher number reading, dont have an explanation as to how yet. . .
aw11power
Oct 10, 2021 04:57 AM
maxinout93
Oct 31, 2015 02:04 AM
salty318
Sep 29, 2015 01:21 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
