What type of grease can i use...
Old Jan 28, 2006 | 06:54 AM
nishfish871's Avatar
My doors are getting stiff and i need to regrease them...any suggestions on what type of grease i should use? You almost have to slam the door to shut it...
This might not be the right area to post this but oh well.
Old Jan 28, 2006 | 06:59 AM
tomservo291's Avatar
Which ones are stiff... front or rear?
If I recall there is some tension bar in the rear doors that gets screwed up and causes them to get stiff. Mine used to be extremely stiff, then one day I closed my rear passenger side door and there was this horrible snapping sound that sounded like a hinge breaking, or something to that affect.
But, everything visible was fine... and amazingly the door swung open/closed like a dream. It's been fine ever since.
Go figure.
Old Jan 28, 2006 | 07:19 AM
Black Maxima
Silcone grease.
Old Jan 28, 2006 | 07:23 AM
MaximaSE96's Avatar
Maxima Owner
white lithium grease works as well
Old Jan 28, 2006 | 08:06 PM
they are stiff all around except the drivers side...i guess it gets used most often..go figure
Yah i knew there was some special grease. Ill try silicone grease or lithium which ever i can find the easiest.
Thanks for the help
Nish
Old Jan 28, 2006 | 09:25 PM
Ridge Runner's Avatar
I use white lithium grease in a spray can.
Old Jan 28, 2006 | 09:42 PM
surfman21's Avatar
dude are u joking me...using anything...lube, wd40, grease
Old Jan 28, 2006 | 10:15 PM
86maxima96's Avatar
I Broke OT
agreed. in the solid form, squeeze tube. just wipe some on the bar and open and shut the door a few times to work it in. should solve the problems.
Old Jan 29, 2006 | 04:01 PM
MadMax92's Avatar
Sounds dumb but I use Vaseline because it is clean and thick. wont leave nasty grease stains in your door jam. and most people have this at home.
Old Jan 29, 2006 | 04:41 PM
PAREDLINE's Avatar
Dont use vaseline. It's water based. It will cause your car to rust.
I'm sure you have it at home too...
Just kidding
Old Jan 29, 2006 | 07:59 PM
MadMax92's Avatar
It's patroleum based dumb *** thats why its called patroleum jelly!
Old Jan 29, 2006 | 08:11 PM
PAREDLINE's Avatar
Read closer genius. It's Petrolatum. not Petroleum.
Old Jan 29, 2006 | 10:46 PM
aussie983's Avatar
Um Both of you got PWNT!
LMFAO its Petroleum Jelly for gods sake.
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
MichMaxFan
Sep 30, 2015 09:18 AM
Bonka
Sep 14, 2015 11:18 PM
TheMafia
Sep 4, 2015 08:26 AM
