Valentine ONE Consealed display gets HIDDEN
Valentine One Concealed Display
Put the Valentine One Main unit above my rear view mirror. I used the hardwire kit so there are no unsightly wires all over the place.
Can you spot the V1 Concealed Display?
Here it is!
I sacrificed my clock as you can see.....it's ok.. I have a clock on the headunit already. So far i'm loving this mod!
Here it is!
The hardwire kit is included with the Valentine One Radar detector.
I used this write up to hardwire the unit:
http://www.freestyleconcepts.com/v1.html
The concealed display is 39 bucks + tax from Valentine ONE. When you plug this unit in the main unit goes DARK.
Yeah so I took out the clock and threw the hidden display back there. I had to cut out the back part of the plastic part holding the clock (if you take apart your clock you'lll seee what i'm talking about). Otherwise, it looks pretty stock. DREMEL def. helps with this mod. I'll try to take some better pics....IT WAS SO DAMN COLD OUTSIDE!!!
If you have any questions PM me and I'll try to answer them.
You can't see it from the outside of the car because of the tint strip.
The write up i linked to, shows a picture of the car from the outside...the main unit is hidden from the front of the car. Not sure if you meant this or my next comment...
The point that valentine makes about the concealed display is that at night time people can't see the main unit's lights cause alll the alerts are re-routed to the concealed display which is usually mounted on top of the power plug that goes into the ou*** or some other discreet place.
Here it is!
Here it is!
here in Va., people who have radar detectors REALLY have to HIDE them....completely. Otherwise it's a fat ticket and your detector gets confiscated. I know people who have hidden the sensors in hood scoops, in the grille, etc and the display in the gauge cluster or ashtray
Originally Posted by irish44j
gotcha...
I think Escort actually makes one that you have to custom install..it's pretty cool. The display is a bunch of leds that you can mount in your dask to make it pretty stock looking.
Originally Posted by jeepik
one thing
the rear sensor from the v1 is halfway blocked( yes it still will work) i had mine the same way and found that i needed to mount it on the other side of the mirror and a little bit down
Ahh ok thanks for the tip..i'll move it over when I get a chance. You noticed a lot of improvement when you switched spots?
thanks for using my writeup. Glad to see its being used for other maxima owners
btw, do you have the straight cord? Seems that you had the cig wire dangling from the detector. Other than that, NICE!!
How did you get to the clock? I might be doing that soon.
Andy
Originally Posted by Andrew
Nice,
Andy
Andy
The hardwire kit COMES witht he straight cord...and the concealed display comes with the straight cord also so you're set to go.
The clock actually just POPS OUT. when yuo pop it out you have to disconnect the plug for the clock then its free.
Then on the back you can see two screws where you unscrew them and then the clock is free. pretty easy to figure out...you just gotta dremel the back of the clock holder out after you unscrew it to squeeze the concealed display in there. I shuodl've took pics...bah..oh well. Since your'e the write up king you can take some pics. =)
gotcha...
NO, thank YOU for the write up...it was EXTREMELY idiot proof.
I won't be doing any mods in the coming future. I have a mortgage and a renovation to do on my place. Perhaps some time in the summer.
Btw, if you had the pics, i would add it to my site. But nevertheless, glad to help you out.
Andrew
Sup man. Glad the write up can help.
Andrew
Andrew
Originally Posted by xTeCaOx
how did you connect the main unit to the concealed unit.....how did you run the wires down the pillar then across under the dash?? and if so how did you get them under the dash??
2. You just tuck the wires in on the pillar and run the wire flat across the headliner. check out my write up: www.freestyleconcepts.com/v1.html
A-
Originally Posted by filtor1
Looks great. studman had his the exact same way. you can see his at maxima.theowensfamily.com under the V1 tab.
