Squeeling at startup with loss of power steering?
Old Feb 1, 2006 | 11:29 AM
Mymax97's Avatar
Hi
Hey guys,
My maxima has a supercharger and when i start it sometimes it will squeel for awhile and i will loose my power steering for say 30secs. Does this have anything to do with the belt on the supercharger and should i have it replaced? Flame on if needed.
Old Feb 1, 2006 | 11:49 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
You may need to tighten it. Last winter, mine squealed like that. Jack the car up and see of you can twist it more than 180 degrees on the segement that is next to the oil pan. If so, tighten it up.
Old Feb 1, 2006 | 12:00 PM
Mymax97's Avatar
Hi
What IT am i looking to twist the belt?
Old Feb 1, 2006 | 02:34 PM
slimer's Avatar
Twist the belt. See if it goes past, whoops, 90 degrees.
Do you know how to tighten the belt? Which kit do you have? V1 or V2
Old Feb 1, 2006 | 02:38 PM
Mymax97's Avatar
Hi
V1 kit and nope i dont know how to tighten the belt.
Old Feb 2, 2006 | 12:17 PM
Chunger's Avatar
My other car is a Hybrid
Power Steering belt is separate from the main (SC) belt... it's at the back by the firewall... get a manual.
Old Feb 11, 2006 | 06:55 PM
choray911's Avatar
The Crazy Azz Cracka
You have air in the Power Steering lines. Jack the front of the car up, remove the PS fluid resivor lid and top off. Turn the wheel lock to lock very slowly 10 or so times with the moror off. Then crank it up and repeat with the motor running. That should take care of it.
Choray
Old Feb 11, 2006 | 09:59 PM
Mymax97's Avatar
Hi
ok ill try that this week
Old Feb 12, 2006 | 10:15 AM
Nealoc187's Avatar
SLOW
Power steering belt is too loose. Tighten the PS belt up. Has nothing to do with the SC belt. Could be the pump too I suppose but the belt is the usual suspect.
Old Feb 14, 2006 | 06:26 AM
MaximaEvolution's Avatar
you probably just need to replace your belts... i know my belts are goin and they squeal a little, and until they grab my rpm's are low, like 1000rpm at cold start.
lowpost99
Oct 26, 2025 06:53 PM
rbarnes
Dec 31, 2015 06:29 PM
Mochedda
Dec 15, 2015 11:27 AM
fastcarny
Oct 12, 2015 07:06 AM
ColdCananda
Sep 20, 2015 10:45 PM
