air intake question
Old Feb 2, 2006 | 03:35 AM
maximaownsyou's Avatar
air intake question
im planning on buying a ram air that is placed where my stock airbox is.
1)would it hurt performance being behind the battery where no air is?
2)take in the hot air instead of any cold air?
3)any other ram air worth looking at other than this one from stillen?
i just dont want a cold air because of issues with taking in water
i know that air intake threads are a but i figured these were not so common questions.
Old Feb 2, 2006 | 05:45 AM
JaKillz2's Avatar
anything which replaces the stock box will help in a way. However air intakes really don't add THAT much hp, at least not enough to be noticable. Anyways, it would never HURT performance. The air temp for a short ram intake isn't hot. The short ram intake options include ones such as stillen, frankencar, berk ect. USE GOOGLE or search the forum. The CAI have not been known to take in water despite their location.
Old Feb 2, 2006 | 09:16 AM
nicks79's Avatar
Dude,
I made one this weekend.. $15 adaptor and K&N cone filter from Pep boys, some SS screws and home made bracket to hold the thing up.
Sounds much nicer, though I kept the stock mid-pipe. I am looking for a used one to replace it with.
Old Feb 2, 2006 | 09:19 AM
upstatemax's Avatar
http://www.berktechnology.com/intakes.html
Thats the one I have, I love it and so does most of the Org. The only true CAI is the Place Racing that you have to cut your wheel well to get the air.
Old Feb 2, 2006 | 09:28 AM
alpinestars™'s Avatar
THIS IS...
Hey upstatemax, how does that intake sound? Im really interested in this Berk Intake, but I dont want too much noise. Does it give a nice growl or does it sound like a 227hp Shop Vac under your hood?
Old Feb 2, 2006 | 09:35 AM
Puppetmaster's Avatar
It sounds just like the Frankencar:
http://www.frankencar.com/movies/stevedyno.mpeg
For more clips go here:
http://www.frankencar.com/media/
Old Feb 2, 2006 | 09:38 AM
THIS IS...
Thanks Puppet, thats just what I needed.
Old Feb 2, 2006 | 09:50 AM
upstatemax's Avatar
I would keep that between the two of you...
Old Feb 2, 2006 | 11:33 AM
THIS IS...
Ill keep that in mind...
Old Feb 2, 2006 | 12:27 PM
JaKillz2's Avatar
Does the apexi filter really help that much more than the offered k&n like in the berk? well not neccesarilly "help" but is it worth an extra 60 bucks?
Old Feb 2, 2006 | 01:08 PM
MxdOut97's Avatar
actually, many cai's have been dynoed and have shown to decrease low end power. many people here have done a GAB which has been dynoed at as much as a 9 hp increase over stock. best part of it all is that its free and easy to make. if you dont know what it is check the do it yourself stick cuz youll probably get flamed for asking
Old Feb 2, 2006 | 01:42 PM
JaKillz2's Avatar
why hasnt the industry noticed how much such a thing improves hp while they are all still making 5ph intakes for 150-200$ Is the GAB BAD in any way? Besides the fact that you dont have a shiny metal pipe in your compartment? mm.. shiny
Old Feb 2, 2006 | 02:12 PM
upstatemax's Avatar
It looks like azz...
I had one till posted my car for sale. The only reason I swithched it out is because it looked better. The Berk sounds nicer IMO and it certainly looks A LOT nicer. If no one will ever see your engine bay and all youcare about is performance, do the GAB. If you want bling and performace, I say go with Berk.
BTW: I think the K&N is more than fine for the intake. The Apexi seems to be for people who dont want to blow thier MAF, but the only way you will do that on a K&N is if you are and dont follow directions.
Old Feb 2, 2006 | 02:29 PM
JaKillz2's Avatar
haha gotcha, well I think im goin to get a berk then. But first I got a couple little questions. 1.) on the left of the stock air "scoop" there is a mounted sensor and wire harness. It mounts to a drilled hole in the plastic of the scoop, using one nut and bolt. What do I do with this if I got rid of the scoop? 2.) On the underside of the scoop, there is some tubing which drops down about 5 inches and attaches to a white box (similar to a fluid tank) but it is empty and I don't see why it is there. Do I remove that tubing if I put a short ram intake in? And what is the box and does it get removed as well? Thanks in advance
Old Feb 2, 2006 | 02:51 PM
upstatemax's Avatar
I removed the tubing going to the "white box" and I have the sensor taped to the front of my battery (it is only an air temp sensor). Some people keep the stock snorkel, it might help get more cold air to the filter... I took mine off because I dont think it will help hardly at all and it looks much better off.
Old Feb 2, 2006 | 02:55 PM
JaKillz2's Avatar
woo woo thanks man
Old Feb 2, 2006 | 04:13 PM
DrKlop's Avatar
Driving is the next best thing
I just wanted to add one more thing which was not mentioned in this thread yet.
You WILL loose some of your low end torque with any intake.
Old Feb 2, 2006 | 04:31 PM
upstatemax's Avatar
The Berk keeps it very low though. I found my lowend was better with the Berk than it was with my Ported GAB.
vingodine
45
May 21, 2016 12:46 PM
A32goldylocks
Sep 2, 2015 06:39 AM
95Maxi
Aug 29, 2015 09:38 PM
cheftoo
Aug 20, 2015 05:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
