Transmission ECU BrOkEn
Old Feb 9, 2006 | 08:30 PM
MaxGordon7's Avatar
SOOOOOOOOOOOO now i get my DEK swap all set up and now i cant go pass 3k in drive. My tranny won't stop tossing codes, ive searched and come up with nothing. How do you reset the transmission ecu? My car is hooked up runs and it feels/sounds great. Just i cant go fast, its like having a 4 banger or driving the corsica i have now all the time. Does anyone know?!?!?!!? I want to beat my maxima please someone help me out
Old Feb 9, 2006 | 08:58 PM
i30ds's Avatar
Armed and Dangerous
You can't reset the auto tranny control module. Did you try resetting the ecu?
Old Feb 10, 2006 | 05:32 AM
njmaxseltd's Avatar
Something tells me it's your MAF sensor messing things up.
Swap it and see what happens.
Old Feb 10, 2006 | 06:48 AM
vsamoylov
if you need a tcm (tranny control module) contact me
Old Feb 10, 2006 | 02:47 PM
MaxGordon7's Avatar
of course i reset the ecu, hmmm ill try this MAF which is where exactly i dont even KNOW ill find it out......
Old Feb 10, 2006 | 03:09 PM
Ninos_Maxima's Avatar
be the change u want2C
unplug your batter for an hour?
Old Feb 10, 2006 | 07:30 PM
motocross416's Avatar
check all the ecu codes and figure out which ones are for real and which ones are because of the swap.
Your maf is before the TB, there is a plastic piece with a connector on it. You'll probably need to check the codes though, I don't think you can see if anything is wrong with it by looking at it, you could try unplugging it though and then starting your car and seeing if it acts the same with it unplugged verses plugged in
Old Feb 10, 2006 | 07:42 PM
MaximaSE96's Avatar
Maxima Owner
make sure ur MAF is plugged in...its the black tube near ur airbox/filter and part of ur intake system that has an electrical plug on it
Old Feb 10, 2006 | 07:50 PM
MaxGordon7's Avatar
well if i unplug the MAF, cars at idle, starts to idle different so i feel like its not. My ecu codes i don't even wanna look im sure its long. Also i think there is an exhaust leak, he left rear(back of engine)header as 01. I belevie im hearing a loud noise up near the engine when in drive, sounds fine parked, could just me be. Seems to be shifting but WOT and little throttle seem to have the same affect on how it pulls. As in it would take a minute to get to 80 mph. I never took it pass 40 mph, don't want to risk it yet. it takes me like a whole block to get to 35-40 but it doesnt rev high, never pass 3k rpms. Ill take the battery out right now and see what happens tomorrow. I'll test her out more tomorrow, thanks for the shout outs.
Old Feb 10, 2006 | 08:03 PM
MaximaSE96's Avatar
Maxima Owner
sounds like ur MAF is bad then...that will cause u not to go past 3k
Old Feb 11, 2006 | 07:56 AM
tavarish's Avatar
fwd gone rwd cr00
tap on the maf, and see if the idle changes...if it does, BAD MAF....or you could just swap it out and see if that helps. 9/10 your TCM is good.
Old Feb 11, 2006 | 08:35 AM
MidniteMaxSE's Avatar
Sorry to ***** the thread but I have a similar problem..My car wouldnt go past 3k also...but it only happened once...i turned off the car and restarted it...and it was fine!
Also sometimes when I start my car...the rpm needle stays at zero for about five minutes...then shoots up..
Any suggestions?
Old Feb 11, 2006 | 02:48 PM
nismos14's Avatar
§è~® f®ÈÄk
The tach is just out of whack. It shouldnt stay at 0 since it wouldn't be running if it was at 0.
Old Feb 11, 2006 | 08:05 PM
I figured that...I want to get a new cluster but I cant find one with TCS..
Old Feb 11, 2006 | 09:23 PM
MaxGordon7's Avatar
It seems to be all good now, she was running good in the snow. Well 6k at 40 mph in 2nd :P
Old Feb 12, 2006 | 09:19 AM
Good...hope it doesnt happen again!
tarun900
19
Dec 20, 2021 06:57 PM
gigabyte
Jan 6, 2017 06:05 PM
Pied
Sep 26, 2015 03:29 PM
