Currently installing aftermarket head unit with ROEM-NIS2
Basically I hooked it all up, I found similar information in this thread:
http://forums.maxima.org/showthread....oto=nextnewest
And I didn't hook up any of the low level (+) speakers but I had ALL of the other cables hooked up except for the blue one (power antanna), b/c my head unit doesn't have a blue cable.
So I plugged it all in, and my front right speaker started clicking after I connected the car battery, I also tried to turn on the stereo and some of the lights on the head unit were blinking quite strangely (not at ALL normal).
So I disconnected it, plugged int the bose head unit and it worked fine. Anyone have any ideas as to why I was having issues with the aftermarket? I checked over the wires and its wired correctly.
Thanks!
Josh
Thanks!
Josh
Originally Posted by Tatanko
I know it works now, but I'm curious...
Did you have the frame that holds the radio bolted in when you attempted to use the aftermarket radio the first time around?
When I get it back (March 8th) I'm going to take pictures of while I'm doing the install and post a guide on here
Not bolting it in was your problem. That is why it didn't work. The tiny little ground wire isn't enough to ground the headunit, so it wouldn't work properly. I made the same mistake.
Weird, at first it screwed up, then the second time it worked fine w/o grounding it by screwing the wire in...
I just tightened all the wires, set it on my seat again, and it worked, was so strange... Too bad I have to wait til march 8th to get the damn head unit back, slow *** best buy service plan
melteye
May 16, 2016 12:02 AM
BunkyMaxima
Aug 22, 2015 12:58 AM
MikesChevelle
Aug 6, 2015 11:36 AM
