Anyone use/have experiences with the "Sonus" system ?
well ive got a new porter cable and im trying to find the best/easiest stuff possible to use...Sonus seems to be popular among many of the detail websites...I wanted to know if anyone ever used it before?...looks like a nice system, theres 3 different bottles, 1 2 and 3 and then theres a specifically designed pad for each solution...people who know of this stuff-lets discuss please... thanks
I have Sonus SFX-1, 2, and 3. However, I never even used the SFX-3 (the ultra-fine finishing polish). IMO, SFX-2 finishes fine, plus with the LSP's that I use: Klass AIO and Sealant Glaze, the last polishes effects would have been dulled anyways. I'm sure when I go back and redo my car using those polishes, that all of my swirls will go away - I was working in poor lighting and it was the first time with any true polishing steps. I like them a lot, but have also heard GREAT things about the Menzerna line of products, as well as Optimum Compound and Polish. I was thinking of picking up a bottle of the Optimum Compound to try to level down my hood a little bit. Check the sig: those polishing steps were about four months old, and my car had three layers of KSG on it. The car also sat outside for 2 months straight, with only 2 washes. (I'm in college...
Edit: I can't Fing wait until summer until I can do that all over again. In the meantime, over Spring Break, I will be going over the car with Klasse AIO to remove the older layers of SG, and then reapplying a couple layers of SG. I can't wait.
).Edit: I can't Fing wait until summer until I can do that all over again. In the meantime, over Spring Break, I will be going over the car with Klasse AIO to remove the older layers of SG, and then reapplying a couple layers of SG. I can't wait.
Dammit, I want to show off my car:
The process:
Wash with NXT
Clay w/ Mothers
Wash again with NXT
Polish w/ Sonus SFX-1 -- PC Orange DAS pad speed 5-6
Polish w/ Sonus SFX-2 -- PC Green DAS pad speed 5
Klasse All-In-One -- PC Blue DAS pad speed 3
Klasse Sealant Glaze -- By hand (only 1 layer in these pictures)
The process:
Wash with NXT
Clay w/ Mothers
Wash again with NXT
I've been using Klasse for the last 4 years or so, and I thought about switching to Zaino or Blackfire, but then Sonus came out with their Acrylic Spritz/Glanz that makes SG removal soo easy and painless!!! Those are the only two Sonus products I've tried and they are very excellente.
Not a fun time trying to get that off. Now, I use a wipe on, wipe off method of applying Klasse SG, and that makes it painless. Also, applying REALLY thin has been my habit ever since...
thanks for chiming in guys .. the paint looks great on everyones car who posted pics .. seems like most people like Sonus....ewuzh your car is sick... BigLou your paint looks amazing with that reflection; nice and clean...
im pretty much decided on the sonus 1 2 and 3, I just hope they dont dry up quick so I have enough time to work them into the paint, iI read a few things about the sonus drying quickly thus not leaving enough time to work it into the paint....Biglou, I havent decided on a final wax yet, I was thinking maybe the Mothers Power wax for the last step .... not sure that I need 4 steps since my paint is already in great shape but I want it to shine like a show car so: sonus 1,2,3 and Mothers power wax(made for machine polishers)
I didnt wanna clay but im not sure if I should..
Claying would definately be beneficial, and really shouldn't take more than an hour's worth of time. If your paint is in good shape, and doesn't have a lot of swirls, then you might even skip the SFX-1 part. However, I really couldn't remove the imperfections I wanted to with SFX-2 alone. Maybe you can post up some pics of your paint? I'm going to post up a couple of before shots of my paint after I upload them so you can get an idea of what I removed.
sonus?
i am unfamiliar with sonus is it just wax or like claybar stuff? have a LOT of swirls but not so much now after i used this meguiers stuff in a red bottle i found in my garage it turned out like this-
i find this tolerable, but with car being black, im gonna need something like a mirror..does sonus do this?
These were the befores.
Note: not all of my swirls came out when I polished. I thought it was the polish, but I'm sure it was just my inexperience. That is the reason I was going to try Optimum Compound, I've heard really great things about that product on a PC.
Originally Posted by rsly33
Hours worth?
Its more like 20 minutes
If you have swirlies, I suggest the 3M Perfect-It line of products. If the swirlies are really bad, use 3M Rubbing Compound followed by Swirl Mark Remover. If the swirlies are mild, skip the rubbing compound and just use SMR. Be careful with the rubbing compound, as it is basically liquid sandpaper (very high grit though). Follow this with a finer polish of your choice, top it off with sealant or wax (or both, sealant first, wax after).
And yes, clay your car. It gets rid of the roughness and makes the paint as smooth as glass
good stuff in this thread ... very knowledgeable ezwuch and biglou ....
looks like im claying guys ...was thinking about getting the "sonus fine claying bar", i read that its safe from damaging any paint whatsoever
resly33: yes I have never clayed a car before, but even for someone who is experienced, I cant imagine it takes 20 mins!... I would guess that thats a crappy claying job.... 20 mins to rub the ENTIRE car carefully ?? ... im also gonna mist as well, ive read that its important to keep the paint wet ?
Yes it takes me about 20 mins and no its not a crappy job.
If im going to clay, after I wash, I dont dry the car. Ill either use spray lube or soap+water. Then after Im done, wash again. There no way, first time or not, it should take an hour.
You are right, it is very important to keep the paint wet, the clay should glide over the paint
This thread should get moved to detailing
sry man, not enough peeps go in the detailing section..sometimes if im lucky there is 1 person in there!
Unless you're getting paid to detail, you really don't have to be on a time crunch. Take your time with it.
Also, I hear very good things on the Sonus Fine Clay. If you haven't already, go over to that detailing forums: www.autopia.org . There are reviews from many members over several different types of products, where you can see what they say. Keep us updated. Again, if you can, post up some pics of your car so that we can see what kind of damage you are dealing with.
Another thing that you can read up on: Autopia's Detailing How-To. You can also purchase products from this site. The forums site is www.autopia.org and the purchasing site is www.autopia-carcare.com.
Mar 12, 2020 12:06 AM
RWCreative
Sep 21, 2015 11:01 AM
