opinion on over wattage bulbs with upgraded harness
i saw this harness+over wattage bulbs on ebay:
http://cgi.ebay.com/ebaymotors/9004-...ayphotohosting
If i install these on my car, will my alternator be able to support the extra wattage since stock low beam is only 45 watts compared to these 80 watt low beam bulbs?
also will these overwattage bulbs damage my headlight housing in anyway?
i have the nokya stage II bulbs 100w/120w. been running it with the wiring harness for about a year and a half now no problems. never heard of the headlight cracking, but hey if it does, time for cefiros. i've heard stories of the sockets melting, but tahts because of stock wiring.
hoenstly, don't expect the greatest lighting youve seen in your life. stick to stock. i got mine because my bulbs blew out, and its pretty dim sometimes driving through rain.
THIS IS FOR 9004 100/80W HI-GRADE HEAD LIGHTS POWER TUNE-UP CONVERSION HIGH OUTPUT WIRE HARNESS KITS, THIS SET INCLUDING ONE PAIR OF 9004 100/80W XENON HID BULBS AND IT CAN TUNE UP YOUR BULBS FROM 100/80W TO 130/110W WITHOUT HURTING OR MELTING YOUR WIRING
Give your car that expensive KRYPTON XENON gas filled HID look bulbs today, the newest luxury vehicles, for a fraction of the cost! Just adding this wiring harness to your car and Take advantage of this super low price on a set of two high wattage Krypton XENON gas filled bulbs for your vehicle.
This is a high power 9004 xenon bulbs with wiring harness conversion kit, having brightness of turning up 100/80w to 130/110w. It has excellent quality and recomendable or those users who love sports, the bulbs and the wiring harness conversion kits I sell are the best power tuneup set out there
Speak english much?
Honestly, would you purchase goods from an ad like that?
Originally Posted by njmaxseltd
Talk about a way with words...... Advertising 101 at it's worst.
Speak english much?
Speak english much?
Now you re making me question about the quality of the harness.....
If the existing harness can't take the upgraded wattage, the simple way to fix that would be to install a pair of ordinary headlight relays somewhere near the lamps. Use the existing high beam wire to energise the relay coil, and run a heavy-duty cable rated at 20 amps from the B+, via an inline 30A fuse, to the relay contact. Then the other side of the contact via 20A cable to both headlight high-beam connections. Similar arrangement for the low beams. Cost you about $15 in relays and about $5 in cable. Simple.
The Frye
Sep 2, 2021 11:03 AM
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
Nov 6, 2015 02:34 PM
