Blew the motor on the dyno!!
Old Feb 12, 2006 | 04:01 PM
chris'smax's Avatar
Well i am officially screwed. Car made 300 whp and 273tq on 10.5 psi. On the last pull though after we let of we heard a clicking sound come from the motor and the car was struggling to run. AFR was actually rich, but i think timming may have been a issue and detonation caused a rod bearing to fail. So now i have to decide if i want to keep the car, swap in a VQ 30, or a VQ 35
Old Feb 12, 2006 | 04:06 PM
JAY25's Avatar
what? thats messed up man. Sorry to here that
Old Feb 12, 2006 | 04:08 PM
jeremykedel's Avatar
damn manthat sux sorry to hear itkeepthe car and swapin a 3.5 I was there a few weeks ago,I just put mine back with anniversary edition motor andtranny.Good luck.
Old Feb 12, 2006 | 04:32 PM
Nealoc187's Avatar
SLOW
Were you spraying just water or a mix? Does your kit have a progressive controller? Do you know for a fact it was spraying?
Old Feb 12, 2006 | 04:35 PM
Tatanko's Avatar
Bacon Lover
I'll say it again:
"Boy I wish I had that problem..."
Old Feb 12, 2006 | 05:18 PM
Jason R's Avatar
aka UNCDooD
chris YGPM. let me know if I can help.
Old Feb 12, 2006 | 05:41 PM
chris'smax's Avatar
80% water/ 20% alcohol. I don't have the a activation light but i assumed it was working since i am only hitting 10 psi w/ a 2.87 pulley and i tight belt.
Old Feb 12, 2006 | 05:53 PM
HarrisH's Avatar
You were spraying NOS?
Did you detonate because your timing was to advanced? I'm getting an SMT-6 or thinking about it, I'm all motor, vq35 4th gen but don't want any motors blowin' on me.
Old Feb 12, 2006 | 06:05 PM
96blackmaxSE's Avatar
boost me.....
Thats rough man...you have too nice of a car to just ditch it, I vote for a 3.5....but thats what everybody says...
Old Feb 12, 2006 | 06:46 PM
cardana24's Avatar
Blown
what do you use for fuel management?
Old Feb 12, 2006 | 07:33 PM
matty's Avatar
Sorry to hear about that man.
What was the milage on the motor and what is your fuel setup??
-matt
Old Feb 12, 2006 | 07:43 PM
I30tMikeD's Avatar
If you were getting bad enough detonaiton to damage the motor it would be evident in your dyno graph.
Sucks man.
Old Feb 12, 2006 | 07:57 PM
95turbo gxe's Avatar
Sucks man.
Sorry to hear that man. Yeah I agree with Mike! Could we see a graph print out on the last run.
Old Feb 12, 2006 | 08:59 PM
Nealoc187's Avatar
SLOW
We are talking about water/alcohol spraying, not nitrous.
Old Feb 12, 2006 | 10:08 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
Did you get the ZDL workin? If so, what were the readings? I tried mine today and will be emailing zbigniew tomorrow.
Sucks chris.
Old Feb 12, 2006 | 11:09 PM
JdoubleOe703's Avatar
teddibear703
i know this is offtopic, but i was wondering, for example if you are dynoing and you have a J & S safeguard, would the unit retard the timing to prevent the engine from detonation and blowing?
Old Feb 13, 2006 | 03:53 AM
chris'smax's Avatar
From what i understand the J&S retards timming when it sense detonation( which i really don't care for since it may be too late).
For fule management i am using Emanage w/ Power Enterprise 510cc injectors.
Slimer, no i didn't get the zeitronix working before the dyno. I figured since the car had been tuned to a very SAFE AFR of 11.5 w/ the water alch injection that i would be fine, but i guess not
Old Feb 13, 2006 | 06:18 AM
HarrisH's Avatar
Wow I've never heard of this before, does this enhance performance?
Old Feb 13, 2006 | 06:41 AM
chris'smax's Avatar
Guys i will post the dyno as soon as i get it from my freind. I was alittle pi$$ed yesterday so i forgot the disk and printout.
One more thing, we used a tail pipe sniffer since my WBO2 isn't working. We knew it wouldn't be accurate becuase of the cuttout, but we figured it would still give us somewhat of a reading. When we were dynoing the AFR showed a peak afr at redline of 11.9 or 12.0 (can't remember). I figure this reading would be leaner than the actual AFR becuase of air being introduced through the cuttout. Does this mean i was actually richer than this reading? If so would it be a significant amount?
BTW that cuttout is working, man that B!tch is loud as hell when it opens up. All those domestic guys came over and were like"damn that is a bad @ss sounding car man"
Old Feb 13, 2006 | 08:36 AM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Oh NOOOOOOooooooooo!!!!!!
Did you pull the plugs yet? Also, go to Autozone or whatever and buy a compression tester Chris.
Did you ever figure out if you had one or two step colder plugs?
Old Feb 13, 2006 | 10:02 AM
LatinMax's Avatar
I wonder if it is what I was telling you about the other day and you actually leaned out at the top end, but did not know it because of the cut-off.
Very sorry to hear that, let me know if I can help with anything.
Old Feb 13, 2006 | 10:08 AM
Nealoc187's Avatar
SLOW
Not the spraying of the water/alky/methanol by itself, but what it does is prevent detonation so that you can run more timing (for more power) or more boost (for more power) without having to worry about detonation. Say for instance your car could only handle 10psi of boost with the stock timing before you started to get detonation. With water/alky/meth injection you might be able to handle 12psi of boost on the stock timing, thus making it possible for you to make more power on stock timing. Or you might run 10 psi and be able to advance your timing, making more power, or a combination of both, maybe 11psi AND advanced timing at the same time, etc.
Check out coolingmist.com, snowperformance.net, devilsownonline.com, etc.
Old Feb 13, 2006 | 11:32 AM
choray911's Avatar
The Crazy Azz Cracka
That blows man!
Been there, done that, bought the T shirt twice.
I hope you have a beater you can drive.
Choary
Old Feb 13, 2006 | 12:24 PM
slimer's Avatar
He doesn't, which is a huge problem.
Old Feb 13, 2006 | 01:09 PM
chris'smax's Avatar
yep, otherwise i'd be like f$$$ it i'll just throw in a 3.5
Old Feb 13, 2006 | 01:11 PM
JClaw's Avatar
If you're willing to put up with 1-2 weeks of downtime for the cams' back and forth shipping, go for the bigger nuts.
Old Feb 13, 2006 | 01:35 PM
chris'smax's Avatar
thats what i am leaning towards
Old Feb 13, 2006 | 01:39 PM
subs1000w's Avatar
sorry about the engine but in my opionion anyone with a heavily modded car that doesnt have a backup deserves what is ultimitly going to happen
Old Feb 13, 2006 | 01:59 PM
chris'smax's Avatar
deserves it my a$$, hell i paid a arm and a leg to get quality parts and a proffessional to tune my car
Old Feb 13, 2006 | 02:11 PM
I30tMikeD's Avatar
Are you saying you had a wide band sniffing at the muffler, but had your cut out open??? You do know that makes no sense right?
Old Feb 13, 2006 | 02:28 PM
IceY2K1's Avatar
Chris,
I'd like you to EXPLAIN in detail how the day went, ie everything that the dyno operator did to how many runs and it what kind of time frame.
However, you NEED to pull your spark plugs and do a compression test before you start searching for a new engine.
Old Feb 13, 2006 | 02:47 PM
I30tMikeD's Avatar
I also don't think you need to worry about swaping in a $1K motor when you don't even know why you blew up in the first place. Too many mods and not knowing what is going on is a bad combo
Old Feb 13, 2006 | 03:05 PM
HarrisH's Avatar
Wow that's by far the dumbest most ridiculous comment I think I've EVER read. There are a ton of cars that are more than heavily modded that run flawlessly. So I take exotics and other high HP cars will uliTIMATELY die?
Old Feb 13, 2006 | 03:11 PM
jac121479's Avatar
very informative and motivational post
Old Feb 13, 2006 | 03:12 PM
I30tMikeD's Avatar
No, he ment that it is not smart to have a heavily modded car without having a second car to drive incase something like this happens
Old Feb 13, 2006 | 03:15 PM
SPiG's Avatar
SomePsychoGuy
Although a beater or dependable backup is a very wise choice, I wouldn't have put it that harshly.
Old Feb 13, 2006 | 03:17 PM
SPiG's Avatar
SomePsychoGuy
I am also very interested in a detailed account, step by step of what happened. Not to discourage a VQ35, but I would triple check everything before deciding to spend a few grand on a new motor.
Old Feb 13, 2006 | 03:18 PM
MyownNismo's Avatar
Future Camaro SS owner
Well that sucks. How many miles was on your motor may I ask. Hope you get back on the road soon.
Old Feb 13, 2006 | 03:35 PM
chris'smax's Avatar
Yes i know it doesn't. They put the sniffer in before i told him about the cuttout. So he just left it there
Old Feb 13, 2006 | 03:43 PM
I30tMikeD's Avatar
Just a guess, but I doubt it was a timing issue. Your not running all that much boost on stock timing. Maybe enought to get some mild detonation, but I wouldn't think enought to damage the motor.
