All 4 Turn Signals won't work ---- Light bulbs okay, Fuse okay
All my turn signals don't work all in a sudden, I checked the light bulbs in all 4 compartments and found their tungsten didn't melt.
And then I also checked the fuse box, but I don't really see there is any fuse responsible only for turn signal, so I checked "fr fog", "L head lamp", "R head lamp", and everything else related to light and they are all okay!
Can anyone please help me to fix this problem. I know I will get pull over soon if I don't turn with my lights on somehow!!!
Thanks x1000.
Thanks x1000.
if you pull out that part of your center console, there is a connector to plug into the back where the hazard button is, if its not plugged in your turn signals wont work.
Have you take apart you center console recently?
Originally Posted by matts95max
check your blinker fluid levels?? that my have nothing to do with it..(don't flame it was a joke. ha ha)
Hey how much of you max you were parting out do you have left? I may need a few more parts.
I checked the hazzard button, the connector is securely plugged in. So I don't think is this causing the problem.
Any other suggestion??
I really don't want to go out and pay the extra labor fee.
Its kinda hard for the hazzard light switch to become unplugged on its own. I've ran into a few that didn't want to come off with force. From what you are describing I'd put my money on the hazzard light switch. Ran into the same problem on a couple of other cars I've worked on.
Originally Posted by Hajime
Not at all. I just get nothing when I put my blinker on.
No light, no signal, no noise.
i had the same problem last year, trust me its the flasher relayer, its under the dashboard right by your knee, i went to a nissan dealer and just bought one and replaced it, its a really small black box and you just connect a wire to it.
Originally Posted by DAVE Sz
Hazard fuse????????????? There are 2 or 3 fuses that can make the turn signals not work. However with no clicking a relay might be the problem.
Besides the hazard one, which others can it be? Also what can cause the Hazards alone to not work but the signals to work fine? Anyone know this?
$50 to $60
It is called a blinker relay which is located where someone said a your right knee sitting in drivers seat under dash. if blinker relay is damaged it would cause no sound no blinking for both the hazards and turn signals..100% it has happen to me once.However i have seen others on an led web site for less money $13 dollars or so...
jerrod99_se-l
Aug 27, 2015 08:27 PM
Viralkill
Aug 17, 2015 10:54 AM
Derrick2k2SE
Aug 12, 2015 06:47 PM
