2002 max audio questions....
Old Feb 15, 2006 | 01:11 PM
BeSeenWithGreen's Avatar
I want to take out the factory sub and put something else in the trunk with an amp, but I dont want to get rid of the factory head unit. First does the factory bose have a RCA outputs? if not than is there a way to hook the new amp up with the wires that go to the factory sub? Thanks any suggestions are appreciated. Greg
Old Feb 15, 2006 | 01:20 PM
TXT-1's Avatar
http://forums.maxima.org/showthread....hreadid=118180
Old Feb 15, 2006 | 01:23 PM
nismos14's Avatar
§è~® f®ÈÄk
You can buy a LOC and use that to get signal for the amp. Then just run power ground and remote to the amp and hook it up to the sub. LOC = line output converter.
Old Feb 15, 2006 | 02:42 PM
djfrestyl's Avatar
Suspension Yoda
You don't even need the LOC.
Where in Philly are you located?
Old Feb 15, 2006 | 02:43 PM
nismos14's Avatar
§è~® f®ÈÄk
True I guess you could splice RCA's into the signal wires.
Old Feb 15, 2006 | 08:35 PM
Near center city, thanks for the info...will get that kit for $100.
Old Feb 15, 2006 | 09:08 PM
djfrestyl's Avatar
Suspension Yoda
You can save yourself the $100 and just splice.
edit: I'm in the Philly area quite a bit...right around 42nd and baltimore.
Pearl96Max's Avatar
I tend to get a bit irritable
Whoa, Please do not spend $100 on an UN NEEDED "kit". It is an absolute waste of money when a cheap set of RCA leads can simply be spliced in.
Old Feb 17, 2006 | 08:33 PM
I'm not sure where I would need to splice them into... Is there a write up?
42nd and baltimore, huh? Not far from Hospital of the Universiy of Pennsylvania where I work.
Old Feb 17, 2006 | 08:37 PM
Pearl96Max's Avatar
Yea there is in the FAQs, otherwise just do it behind the HU, my preference anyway.
Old Feb 17, 2006 | 09:06 PM
Nice thanks Pearl
Old Feb 18, 2006 | 05:29 AM
djfrestyl's Avatar
Suspension Yoda
If ya need help let me know. Next time I'm down there we could meet up I'll give ya a hand.
Old Feb 18, 2006 | 07:51 AM
technogeeky's Avatar
Any advice for the non-bose system?
Is it possible to mount components inside the stock a-pillar speaker holes?
Old Feb 18, 2006 | 07:54 AM
Not to hijack - I thought a noob can post a new thread after 15 posts.. is this not the case?
Old Feb 18, 2006 | 08:08 AM
djfrestyl's Avatar
Suspension Yoda
Yes, components in the stock A-pillar location is fine.
You should be able to post a new thread.
Old Feb 18, 2006 | 08:34 AM
Gapp's Avatar
I spliced into the harness going into the amp in the trunk. I got the wiring colors off the Owens Family site. Anyone know the link? I ran power from the battery and ran a short ground wire. ( don't use the factory ground in harness, you'll get nasty interference) Everything wire you need to do 1 or more amps is in that harness including the remote wire for the amp on/off.
SUPER EASY INSTALL!!
Old Feb 18, 2006 | 02:51 PM
Good stuff I got to check out that site. Thanks
We can meet up sometime when it gets warmer outside, I aint doing any mods in this cold
Old Feb 18, 2006 | 02:55 PM
This should be it... http://maxima.theowensfamily.com/
Robert Schneeweis
Jan 11, 2017 06:47 PM
Excalibur23
Oct 13, 2015 04:33 PM
BrandonCause
Sep 20, 2015 10:20 PM
GregL65
Sep 7, 2015 10:33 PM
Justin Kroll
Sep 2, 2015 11:06 AM
