3.5L w/ SC is now underway
Old Feb 20, 2006 | 01:58 PM
chris'smax's Avatar
Well the shop started on my car today. Hopefully it will be done by the end of this week or begining of next week.
The setup will be as follows:
3.5L w/ SC (2.87 pulley, cai, 3"charge pipe)
ARP rod bolts
JWT 3.0L cams(if my buddy comes through )
Hothsot headers
Greddy Emanage w/ injector & timming harness
3" exhaust cuttout
J&S (next couple of weeks)
Cooling mist water/ alcohol injection
I will keep you guys posted on how it comes out. Hopefully i don't end up
Old Feb 20, 2006 | 02:05 PM
THT's Avatar
THT
Throbbing member
Wow...is this the first SC'ed 3.5L-swapped Maxima? I know MardiGrasMax is turbocharged but I can't recall any supercharged ones...
Hope all goes well!
Old Feb 20, 2006 | 02:07 PM
gameover03's Avatar
hes a 5 gen..sc'd 5.5 gen w/ 3.0 equipment
Old Feb 20, 2006 | 03:09 PM
JClaw's Avatar
2.87 pulley is 12 psi, right? Make sure you have giant tires up front.
And to think I like to believe my N/A one pulls.
Old Feb 20, 2006 | 03:57 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
349.999999whp/310wtq....
Old Feb 20, 2006 | 04:11 PM
IceY2K1's Avatar
Chris,
Make sure you get the J&S gauge or at least the LED C MAX has....
Old Feb 20, 2006 | 04:17 PM
Kevlo911's Avatar
Kevlo for President
Originally Posted by IceY2K1
Chris,
Whats this LED do
MaxGordon7's Avatar
to da max, smash that foot on the gas VROOOOOOOOOM
Old Feb 20, 2006 | 04:30 PM
IceY2K1's Avatar
http://forums.maxima.org/showpost.ph...&postcount=104
I don't think John@J&S sells this as an option, it sounds more like a custom piece.
Originally Posted by Kevlo911
Whats this LED do
Old Feb 21, 2006 | 05:01 PM
rbrown81's Avatar
But why is teh Rum gone?
Let us know how it goes. Can you use Matty's starter kit or are you piece parting the setup?
Old Feb 21, 2006 | 05:32 PM
chris'smax's Avatar
My car has been supercharged for a over a year now. i am just using my stuff and swapping it on to the 3.5
Old Feb 21, 2006 | 06:00 PM
rbrown81's Avatar
How are you getting around the timing chain cover issue?
Old Feb 21, 2006 | 06:14 PM
matty's Avatar
Hes using a 3.0 liter timing chain and cover, so therefore he can use the 4th gen supercharger braket and get away with it.
Chris,
Make sure you take some shots of the work while in progress.
-matt
Old Feb 21, 2006 | 06:21 PM
chris'smax's Avatar
Chris,
-matt
neeevvvvaaarrrr. It's top secret
j/k i will snap some pics this weekend when i go to the shop
Old Feb 22, 2006 | 06:12 AM
chris'smax's Avatar
I think i'll put my 18x10's up front and my 18x8 in the back
Old Feb 22, 2006 | 08:19 AM
MaxInProgress's Avatar
Proud of his GroceryGetter!!!!
nice chris gl with the setup its goona be nice downt blow this one , take some pics and cant wait to see your progress
Old Feb 22, 2006 | 10:33 AM
rbrown81's Avatar
-matt
Any modifications needed to make it fit?
And yes, definetly take some piccies for us.
Old Feb 22, 2006 | 04:18 PM
meccanoble's Avatar
Sports Button FTW
i cant wait to see this. The numbers are going to be awesome.
Old Feb 22, 2006 | 04:30 PM
Jason R's Avatar
aka UNCDooD
awesome. glad to hear you are going the 3.5 route.
Old Feb 22, 2006 | 06:37 PM
95maxrider's Avatar
Lightly modded
This is gonna be good....can't wait to see the results!
Old Feb 23, 2006 | 08:36 AM
Starchild2K2SE's Avatar
Chris,
-matt
My friend TJ Max told me this a while back at how I could make the sc kit from a 4th gen work on my 5.5, I think I might be going to him for more resources...
Old Feb 23, 2006 | 09:00 AM
IceY2K1's Avatar
You have to remove the VTC pullys, which means your ECU would at a minimum throw a CEL. Not sure about limp mode, etc..
It is easy to run a VQ35 w/VQ30 timing equipment/cover off a 4/5.0 gen ECU, but 5.5gens will have complications to figure out.
Old Feb 23, 2006 | 08:12 PM
Nismo3112's Avatar
Custom User Title
Woohoo!!! That will be some serious fun..
Good luck with everything mang!
Old Feb 24, 2006 | 09:29 AM
vsamoylov
well let the countdown begine
Old Feb 24, 2006 | 10:03 AM
Blu's Avatar
Blu
the tits
finally a FI'ed Maxima 3.5 without the power robbing JWT ECU. Can't wait until its up and running smoothly.
Old Feb 24, 2006 | 07:20 PM
LatinMax's Avatar
Keep us posted. I hope it goes well for you.
Also, you should make alot more that 350... I did that on my setup and you are getting 1/2 a liter more space.
Old Feb 26, 2006 | 09:22 PM
choray911's Avatar
The Crazy Azz Cracka
I just got wood! good luck on the uncharted territory.
Choray
Old Mar 1, 2006 | 10:48 PM
ewuzh's Avatar
Update & pics?
Old Mar 2, 2006 | 12:17 PM
RR5's Avatar
RR5
Cant wait to see where this goes.
Old Mar 2, 2006 | 06:34 PM
maxspeedse02's Avatar
Thinks he is fast
Is the timing chain cover the only thing holding back aftermarket manufacturers from making a supercharger kit for the 5.5 gen? If someone like vortech made one I would be all over that shiznit
Old Mar 2, 2006 | 06:35 PM
vsamoylov
no not the cover but the vtc
Old Mar 3, 2006 | 07:41 AM
IceY2K1's Avatar
What do you mean?
Old Mar 3, 2006 | 07:42 AM
vsamoylov
What do you mean?
what do i mean? i mean tthat the vq35 have vtc on both sides. yes you could remove them and put the vq30 tming parts on but then you will get a code and the engine might go into limp mode.
Old Mar 3, 2006 | 07:47 AM
IceY2K1's Avatar
So, it is possible to remove the VTC and still run the SC on the VQ35 timing cover?
No, that's why he was correct...nobody wants to make a new bracket that fits the VQ35 timing cover.
Old Mar 3, 2006 | 07:53 AM
vsamoylov
the vtc is more of a problem then the stupid timing cover. and its not a bracket that needs to be made. did you ever see how a sc is bolted on a
vq30? the closest sc i can see working is the sc from hks for the 350z
Old Mar 3, 2006 | 07:55 AM
IceY2K1's Avatar
Just in pictures....
If they make a bracket that holds the SC, then 5.5gens are in business.
The VTC function doesn't matter.
Old Mar 3, 2006 | 03:01 PM
GBAUER's Avatar
Piece of advice: change the piston rings while you have it apart. As some of you know, my 3.5 burns as much oil as it does gas. Pretty sure it's the rings, byt I haven't torn it down yet.
Old Mar 3, 2006 | 04:05 PM
Jason R's Avatar
aka UNCDooD
i'm sure most VQ35 owners don't sit in the parking lot at meets and go to the car and start it just to rev it up every 5 minutes.
Old Mar 3, 2006 | 08:07 PM
matty's Avatar
Not yet ICE
-matt
Old Mar 4, 2006 | 01:03 AM
rkyat's Avatar
hmm, so whats the latest?
