Hotshot headers on a 4th gen?
Originally Posted by Kevlo911
Add EGR bung to headers or get rid of your EGR. Simple as that.
"They will not work, and you will not pass emissions if you do get them on your car. HS have no EGR port, where you have EGR and if you don't hook it up NY will fail you on emissions. 01-03 have no EGR and HS headers are designed for them. My 01 has no EGR and thats why I can run HS headers with no problems."
Like I said, you will need to add an EGR bung or remove your EGR system. I do not have emmisions testing in FL so I do not have to worry about anything like that.
Just hurricane's ftl.
Originally Posted by Mr Willis
I cant post or do anything can someone help me. Moderator hasn't got back to me yet. WTF!!!is it because i'm new.I've been a member for like a week now.
15 post rule newbie.
3 posts back to back with 0 info in a thread that actually needs information isnt smart either way. Make 15 USEFUL posts, and you can do whatever you want. Then donate, and the world is yours
Originally Posted by RockfordMax
3 posts back to back with 0 info in a thread that actually needs information isnt smart either way. Make 15 USEFUL posts, and you can do whatever you want. Then donate, and the .org is yours
Originally Posted by Nooblet
COME ON HELP!!!!
Originally Posted by Wannabe backyard mechanic
You're gonna have to move the o2 bung that's on the front header because the a/c compressor will be in way
Originally Posted by JSutter
i have been running no egr for months with no cel, you just need to plug the vacuum line going to the egr solenoid.
Itll be ****ty for emissions, might throw a CEL, but it actually keeps your IM cleaner due to not having exhaust gas going through it. Some people have removed the entire EGR system, but alone it does nothing pro or con, so it takes something like this to make it worth doing.
So do the hotshot headers include a y-pipe? or can they bolt up to a y-pipe (ie stillen, budget, etc).
What the gains? Any dyno's? I havent even heard about this, or maybe i have but just didnt pay attention
Theyre basically (from what i can see) the same as cattman.... But 350 dollars cheaper.
www.hotshot.com
www.hotshot.com
Originally Posted by ti2tmax
Any driveablity issues with this? I'd like some info on the process of doing this if you would...
Originally Posted by showoff
How do you add an EGR Bung?
On Hot-Shot's website they only show headers for a 3.5L, will these headers fit a 98 4th gen??
http://www.forums.maxima.org/showpos...32&postcount=2
http://www.forums.maxima.org/showpos...0&postcount=15
I think the website your looking for is www.mynismo.com
They will fit, regardless of the EGR bung. You will need to add an EGR bung if you want to keep the EGR.
The only slight issue (and I emphysize slight) that I have with the HS's on my 4th gen is it gets very close to the body of the car at one point. It doesnt actually touch, but when letting off the gas in first, you will hear a slight tap as the engine kicks back and the pipe hits the underside of the car.
MAXSE5SPD
Sep 17, 2022 04:00 AM
RWCreative
Sep 21, 2015 11:01 AM
Violator
Sep 9, 2015 10:14 AM
