Belt Tension
For the AC belt, (the outer one), you need to loosen the bolt holding the tensioner, then turn the tensioner adjust clockwise looking from above. Then retighten the retaining bolt.
The power steering belt is opposite - once you've loosened the pivot bolt on the back of the pump, and loosened the tensioner bracket bolt, you turn the tension bolt counter-clockwise as you're looking at it from below the car. If the pivot bolt isn't loosened, or you're turning it the wrong way, you can and will bend that bracket or break the adjust screw.
Dave
Dave
Dave
Dave
05' MaximaMan
Oct 8, 2017 06:36 PM
