Cold Weather Start
Old Mar 1, 2006 | 07:37 AM
matty's Avatar
Cold Weather Start
My car usually starts perfect in the cold weather, I would just like to know what all your cars "Rev" to in the morning. Please state what temperature outside it usually is and what it revs for.
About 15-20 degrees it will start up and be at 1700 and slowly rev to about 2100 and then settle after about 15 seconds of revving at 2100. The colder it is the weirder it starts.
370's
Lightweight flywheel
3.125 pulley
Full 3" exhaust
Let me here yours now COLD guys !!
-matt
Old Mar 1, 2006 | 08:12 AM
MaxInProgress's Avatar
Proud of his GroceryGetter!!!!
When its 15-20 degrees outside my car start off at about 1300-1400 and drops down as it warms up to about 600-700.
nismo 555
walbro
t4 turbo
3" turbo back
Old Mar 1, 2006 | 08:19 AM
matty's Avatar
I wonder why my car is reving so high when I first start it in the cold weather ?? Could something be faulty ?? Or is it becasue Im not "controlling" my injectors right now with anything ??
-matt
Old Mar 1, 2006 | 08:49 AM
that is revving kinda high.....im not sure what the cause of that would be to be honest with you....
Old Mar 1, 2006 | 09:33 AM
Stillen Maxima's Avatar
Pay to Play
370's
3.125 pulley
Full 3" exhaust
-matt
I've been wanting to ask the same question and let me tell you matty that my car starts the same way as yours. When the weather is cold like u said it revs to like 2100RPM and as it warms up the RPMs drop slowly to its normal rev. And i have the same set up as you do.....sooooo i dont know what the problem is, if there is one? Im thinking it could be the cold weather because when the day is nice and warm it doesnt rev that high.
Old Mar 1, 2006 | 05:59 PM
matty's Avatar
Anyone have any ideas...lets discuss this
-matt
Old Mar 1, 2006 | 07:03 PM
JamesNH's Avatar
Fast idle Cam?
Old Mar 4, 2006 | 07:48 PM
matty's Avatar
Any other ideas.....Ive never had this happen to me in my car....Its reving to about 2100-2200 RPMS in the morning. Definetly something wrong
If I jiggle the shifter back and forth the rpm's tend to drop to about 1500-1700...really weird
-matt
Old Mar 6, 2006 | 07:35 PM
iansw's Avatar
My car also hits 1400 then slowly settles to about 800RPM.
I do get slight hesitation when moving at about 2400-3000 RPM when cold. Once it warms up even a little - it's fine. The Z32 MAF is the culprit as you've seen me speak of before.
Old Mar 6, 2006 | 07:49 PM
matty's Avatar
Well if I start it in gear, say 1st gear, in the cold morning, its completly stays right at 1500 then drops down while warming up. The next morning, same temp.< start it in 1st gear, then 5 seconds later pop it in neutral and it goes right up 2100-2200. Very weird. Could it be the part nuetral switch. What else could it be
-matt
Old Mar 7, 2006 | 05:58 AM
iansw's Avatar
I don't think that would be the P/N switch. If I push my clutch in, (P/N Switch On) the idle doesn't change until I give it gas or put it in gear and engage the clutch. Also, that switch doesn't really work mechanically. It's purely a safety device for starting the car - nothing to do with how the engine runs.
If you have the clutch pushed in and the stick in 1st gear - then you are still in Nuetral as well.
Old Mar 7, 2006 | 07:55 AM
matty's Avatar
Thats the same thing I was thinking as well. Something in there is wrong, like a sensor. What else is there that would sense it. With the clutch down, and pop it in 1st, it dropps right down to where it should be (1500)...My mind is boggled.
-matt
Old Mar 22, 2006 | 05:24 PM
matty's Avatar
Could the Coolant Temp Sensor be causing this ?? I am getting a weird starting issue when cold. a really slow crank then it slowly turns over and stumbles then revs really high.
-matt
Old Mar 23, 2006 | 06:22 AM
I30tMikeD's Avatar
I get odd things with my idle when the car is dead cold. I can't go over 20% throttle till the car warms up a bit, it will just bogg. I sometimes get a really high idle as well upon cold start up. But in 4-5 minutes everything is fine and the car runs like a champ
I guess I just look at it differently. I got so much crap done to my car that it doesn't bother me if it needs a few mintues in the morning to get going.
gustavison
Oct 4, 2015 06:50 PM
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
tardrex
Sep 11, 2015 07:35 PM
trungg86
Sep 4, 2015 04:58 AM
