Just got FSTB, no instructions, Install help
I bought it from Streetbeat customs and it is made by Matrix. It looks very straightforward, but when you put it on, is the logo on the bar itself usually facing backwards? I could care less about the logo, but I was wondering if it was backwards or not. Also, nothing else in the strut comes loose when you take the nuts off right?
Thanks.
Thanks.
answers...
1. your bar should only fit in one direction... if you do have one that fits either way, then install it to your liking.
2. nothing will come off as long as the car has all 4 wheels on the ground.
Enjoy!
justin
Enjoy!
justin
Yea, mine when installed ends up "upside-down" (you can't read the word Matrix when you're looking from the front of the car). If it bothers you, you can simply switch the brackets.
Since we're on the subject, does anyone else have like this black foam sleeve around the AC line (metal pipe attached to pasenger side strut housing that runs just under FTSB bracket) that seems to be "free" along that bend just after the FTSB bracket? I noticed it today when I was adding some fluids. Is it supposed to be used to protect something else along the pipe? I'm asking only because I decided to slide it in the small gap between the FTSB and the AC pipe (paraniod about stories I've heard where FTSB rubs against and damages AC pipe..) Thanks.
I would also like to know about that foam sleeve because I noticed that the FSTB is a really tight fit over some components in the engine(couldn't tell what they were cause it was pitch black outside).
Got the Matrix too from Streetbeat...
Agreed that you just switch the brackets to make "Matrix" appear upside down or vice versa.
I had the same deal with the black foam sleeve on the AC pipe, I pushed mine down a little bit and it looks okay. Guess you could put something between them if there's alot of friction between the two.
Torque wrench...probably a good idea to use one, I don't know how you can tell how tight it is without one but I've hear stories of people stripping those bolts if they're too tight and they take a hard corner
Thanks.
Thanks.
Re: easy
Originally posted by 1Phat Max
man install fstb is one of the easiest mod you can do by yourself...
take of the bolts from the stuts slap on the sturt bar tighten the bolts and have a beer and enjoy tighter front end in turns....
This is a no-brainer, if you can't figure it out you really shouldn't be working on a car.
IMO, it's there to insulate the pipe. Whenever liquid flows through a pipe there is turbulence, I think it's just a precaution that if that pipe jumps around in there a little bit, it won't make a "banging" noise.
I agree with you though, pretty convenient to just slide it underneath the FSTB. That's what I did.
Re: easy
Thanks.
Thanks.
Originally posted by costcowholesale
I got an 99 model, do I have to cut the piece of metal that sticks out from the tower thats over on the drivers side? or can I leave it there when I get my FSTB?
Re: picture
Originally posted by Roman-dude
Does anyone have a picyure of FSTB installed?
