steering wheel shake
Old Mar 10, 2006 | 10:40 PM
rome06's Avatar
after putting my coilovers / struts on, everytime i shift into 2nd going about 20 the steering wheel starts shaking....same thing happens in 3rd in low rpm??? is this just an alignment issue or what else can it be??? thanks
Old Mar 10, 2006 | 10:53 PM
Fr33way™'s Avatar
Wild for Width
Have you replaced axles?
Old Mar 10, 2006 | 11:34 PM
sonicrunch's Avatar
make sure your lug nuts are tight
Old Mar 11, 2006 | 12:29 AM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
Make sure the 3 14mm (might be 12's) nuts that bolt the passenger side axle to the motor are tight.
Make sure all your suspension bolts are tight.
Motor mounts mihgt be getting weak.
Did you get an alignment?
Old Mar 11, 2006 | 01:54 PM
rome06's Avatar
i just replaced my axles 2 months ago so i know all the bolts should be tight down there.....no havent gotten an alignment yet...
Old Mar 11, 2006 | 06:04 PM
96mAx2fast's Avatar
Def an alignment!!!!!! everytime you remove your suspension, its needed!!!
Old Mar 11, 2006 | 06:09 PM
Juicey's Avatar
This ORG has saved me $$$$$$$$
Balance your tires. Yah I know doing what you did doesn't change the balance but still perhaps your tires have just now worn enough to require it.
Old Mar 11, 2006 | 06:38 PM
99grnmaxgxe's Avatar
Allignment FTW.
Old Mar 14, 2006 | 02:08 AM
Mizter6's Avatar
i sometimes experience this only my car is idle or moving without my foot on the gas pedal
JoshG
51
Sep 21, 2015 10:41 PM
Bonka
Sep 14, 2015 11:18 PM
2kmaximel
Sep 10, 2015 08:13 AM
SusieQQ
Sep 9, 2015 12:14 PM
coasterswim
Sep 2, 2015 07:43 AM
