3.5L supercharger
3.5L supercharger
i see alot of 3.0;s runnning superchargers and i've heard that you can replace the timing cover on the 3.5 to the 3.0 to bolt on the supercharger. i really want to supercharge my 5.5gen and i was wondering if anyone has done this yet. The 3.5 has tons of potential for power and a supercharger would make great mod. I had nitrous but the reliability became an issue, i want something thats easier to monitor and i want readily available power. Any info from any one that has had an experience with this would be awsome. Thanks!
These have some interesting information.
http://www.forums.maxima.org/showthread.php?t=393554
http://www.forums.maxima.org/showthread.php?t=378237
http://www.forums.maxima.org/showthread.php?t=222578
http://www.forums.maxima.org/showthread.php?t=172848
http://www.forums.maxima.org/showthread.php?t=442380
about what? something no ones ever done, no one has posted nething about a sucessful 3.5L supercharger. And the ones that are trying are all 2000 and 2001's. Im looking for a true 5.5gen S/C! The electronics on the car are also something i've questioned but if the 3.5 in the 350z has been S/C with hassale free plug and play installation there should be something adaptable for our max's. I do appreciate the link of forums, i was unable to find as much info as you provided. Thanks.
Originally Posted by soonerfan
dont do this cr@p in a thread. thats what PM is for
Theres alot more useless thread than me asking where hes from.
and the reason I ask is i know someone that is selling a S/C that this guy might be intestead. I dont check my PMs often nor do I even ***** up this site when I have my own to run.
Now I remember why I never be welcome to this site..
Originally Posted by PRO - 1
since you have a half of billion maxima owners on this site you might as well charge everyone here to be on it.. since it seem that every little comment or thread will overload the server.
Originally Posted by indecentmax
so sooner you know of the top secret 3.5L s/c? I want to know more!
smiley gave it way. It has been done on a 3.5L, just not in an A33B chassis.
No one on this forum has ever done it..and if they have, they've never psoted about it.
There has been a turbo set-up though.
You'll have to search for that link because I don't feel like giving it now.
You can gain a bit from the links I provided and have at least a plan for what you might need to do in order to get it to work.
Donate and do more research.
If y'all wanna be pioneers, here's an idea:
Try to build a roots style blower with an extension shaft. The one pictured is the Comptech SC for the Acura TL.
http://forums.maxima.org/showpost.ph...7&postcount=19
but they would have to totally design a new I/M for it wouldnt they ? theres barely room to run the shaft on either side to have it belt driven? you would probally have to take out the power steering resvoir just to have room not to mention the A/c lines ? it seems like tight work in the engine bay as it is..
Why hasnt anyone with a 3.5 (5.5 gen) use the 3.0 heads or changing the timming cover as stated earlier ? S/C it with a aftermarket piggy back? I know NOTHING at all about what TS does for those ecu because they never made one for a 2000 so I dont what gains are in store. I dont know how much differnce the 02-03 compare to the 2ks. But wouldnt this be Do-able with the Stillen S/c or Pro Charger setup ?
Originally Posted by nismo_star
Been done, it aint mine, but its been done in a a33b chasis and the pic is 3 years old
Want one ?
Contact Harry @ paradox-systems.
Who's is it? Any info on this?
EDIT: I looked through the cardomain that picture was on, and I noticed it's an A33A cause of the 2k-2k1 interior (if it's the same car)
Originally Posted by naijai
would that be before or after you blew the engine while holding it for 20 secs at almost redline
Anyways that pic of the 3.5L s/c looks like heaven thanks for the lead, never thought of that.
If that picture has never been posted or that guys car discussed on this forum, then I don't see why people have problems with reposts. There is always to information that comes in from new members and old ones that may have not brought the subject up.
Want one ?
Originally Posted by 03maxima1
Well he said Contact Harry @ paradox-systems.
me and Joel were talking about this, and it seems like a feasible custom job you can do, using a custom centrifugal (sp) S/C unit and a decent engine management system. he had been speaking with Comptech and said their system, which uses a shaft like that because of the placement of the pullies but is a screw style nets about 40-60 whp. i would expect this to give similar gains, but would require A LOT of custom tuning.
Its a publicly available kit overseas, Polak, it aint my car, I went the other way on boost setup, which is on another cardomain site, which I will eventually post up pics once Im all done.
The photo is 3 yrs old, and this is the first time is it posted on Maxima.org.
Harry and I have known about this SC kit, but weren't too thrilled about the turbo kit they produced for VQ30 motors, so it was never pursued.
I did use their front motor mount design to create the necessary space to run 2.25" ID up pipe and 2.75" ID downpipe on an automagic w/o going under the tranny pan. I did use piping technique originally for front mount intercooler, then to SX7R'S IC setup, and now on Air to Water PWR 6x6 'bullet' style.
The amount of problems we had installing his turbo kit, turned me off to the idea. AIC(Additional Injector Controller) is nice idea, but hate all the splicing. I simplified all that with a BEGi FMU, thanks to the experience of another .orger whom used on their 2k1 S/C w/ 2.87" pulley. The extra compensation is controlled by a Fields SFC Hyper R, which at the same time kills my speed limiter.
I threw the pic up, just to show that IT IS POSSIBLE. I know for fact the S/C kit did run fine, and the kit pictured ran 7psi. No dyno #s, or its somewhere in the email records from 3 years ago in 2003.
I'm honestly not sure if Harry wants to attempt to import the VQ35 S/C kit, but if you can generate the interest, maybe he will. I simply let the cat out of the bag after all these years, cause you all should know 'anything' is possible.
Dammit i want that.....**** i'll right now up front if anyone knows were i can get the s/c kit for my 2k2 max...... and yes i wanna run faster than 12's. C'mon its either this s/c or umma start fabbin up a damn tt kit for my car.. think its possible???
I have since lost any and all knowledge about that picture. I dont know how to get in touch with them anymore..
Speaking of my AIC, I'm having problem with it.. The fuel line is leaking.. Think you can help?
