Does your car "Buck"?
Does your car "buck" a little or a lot when in a lower gear at rpms under 3000 and on the throttle at under 15%? I seem to get this "bucking" like feel with the car under these circumstances, and it wants me to believe that it's a synchro issue, then again this is the first car that I've had with the drive-by-wire throttle. I'm not sure what this might be related to, but leads me to conclude that this can't be normal. Any experiences or fixes would greatly be appreciated.
btw, this is not the same type of "bucking" when the car is about to die because you are in too high of a gear and moving at a very slow speed on the throttle. I'm not a stick shift noob, that is different from this experience I'm having.
My 5-spd bucks without fail every time the engine is COLD in 1-3 gears. I usually baby it until it's warm anyway so it isn't too big of a deal.
On second MAF and replaced only one coil. I've heard this is a common problem.
BTW, flooring it sometimes makes it worse.
I believe the problem your describing is normal with the max. In first gear it bucks alot cause the gearing is so short.......That's just the way the car is and you'll have to learn how to engage/disengage the clutch smoother to avoid the bucking.
Originally Posted by Deckdout2
There is a slight buck as if not enough fuel, or if tranny related, possibly synchro issues. I'm a 6-speed btw, so I don't know the effects from automatic drivers.
Originally Posted by jdmaxima89
I have a 2000 auto... and mine does this also when the engine is cold and i first start to drive it. Only does it in first gear though... and also only does it right when I start to drive. If I stop at a stop sign or something... it doesn't do it anymore.
Originally Posted by cpuguy06
mine bucks when Im going about 40, both when I let off the gas, and when I hit the gas again. I have auto too though.
mine does the same exact thing...i always thought it was because the gearing is so short....if i want to release the gas in a low gear, i HAVE to depress the clutch or else my car will buck back and forth....and when it's cold, my car will sort of buck just like you said in gears 1-3....
Originally Posted by Puppetmaster
Mine does something at low rpms once in while, but to me, its more of a shudder, so I'm not sure if that's the same as what you're describing.
Yeah I have to do that as well. That might be something in regards to the drive-by-wire. The "shudder" will also make my rpm's wavey, (needle). Does yours do the same?
Let off the gas and the car will buck like crazy. It's annoying but I believe they all do that..........
But I know what you're saying and mine does that when I let off the gas suddenly (in low gears) too, and I'm pretty sure that's how it is on most MT cars.
i guess this is where auto comes in handy
but in all seriousness, just before my ABS sensor was about to die, this is what i felt. the car was bucking/rocking/stuttering and then at higher speeds it went away. it happened so consistently sometimes that it stopped freaking me out, i knew what it was. but it caused my warning lights to come on and everything, not sure if thats what you guys are having...but since you all have 6 speeds and can all describe the same basic thing, i guess its common with the 6 speed?
I didn't quit understand you, but my car does the same and so did the 6 speed i test drove before buying this one. I am pretty sure its normal. Let off the gas and the car will buck like crazy. It's annoying but I believe they all do that..........
Blu and I took a test drive after work and we think that my issue might have something to with the suspension. I'm going to have to take the wheel off and see now. It does shudder, but when we paid real close attention to it, it was like it's more of a wobble from side to side. This is a new situation that just arose a few weeks ago. The other abnormal low gear/rpm/speed bucking traits are normal or at least have been around for a while.
I'll update my findings. Thanks for the inputs, and keep them coming if you have anymore.
When my car is cold, if i let off the gas sharply, its like i get hit with a baseball bat lol
Once it warms up to decent operating temperature, none of that lol
I think this is normal on all MT cars, the direct connection between the engine and drivetrain [unlike the torque converter on AT] will cause the car to buck if engine speed drops [especially when in low gear]
I'm not 100% sure why this is more evident when the engine is still cold though... maybe the engine doesnt "gradually" slow down
I know what you guys mean exactly, 01 5 speed- i posted about maybe my MAF being bad again but this sounds pretty much right on the money of what my car does. Its real bad when its cold but accelerating slowly its like i have hydraulics sometimes. You know what, mine also does it crusing in 5th, i get the exact same shudder you guys are talking about, but in 5th gear il get a shudder too like the engine skips once, its weird
Then again, i have had the MAF done (at the dealer under warranty) but have NOT had coils done yet and am on 80,000 miles on original plugs
You can definately rule out scnchro issues. That causes a grinding when shifting gears not a bucking.
This sounds like the normal behavior of a Maxima. You have to be careful with it at low speeds. It feels like the car flexes and the suspension compresses in a way that causes the bucking when they rebound. You just have to know how to control the throttle to avoid it. The Max is very sensative to throttle imput at low RPM. Much more so than a 4 cillender or weaker 6 which has no low end power.
The reason some people only experience it when the car is cold is because the car is in "high idle" until it reaches temperature. This causes throttle responce to be different than when the car is warmed up. Once it warms up it behaves like they're used to and it's fine.
I believe this is a fuel delivery issue and there is a TSB for it. Well...at least there is for 01 5-speed. Im not sure about 6-speeds. The dealer will reprogram the ECU if you are under 80000 for free of you bring in a copy of the TSB.
Originally Posted by siren001
Whats the TSB on it? would it count for 01 auto?
http://maxima.theowensfamily.com/tsb/
It's not near as bad as the total POS car I was driving before I got this Max. My father-in-law let me use his spare beater '92 Toyota Corolla while I was on my 4 month long 6-speed Maxima quest. Talk about bucking! That poor Crapolla bucked so bad I thought the engine would drop out. When the engine was cold it was pure comedy, the front wheels would almost come off the ground.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
altome15
Aug 10, 2015 07:05 PM
