Can I tap into a wire and make the car stall when attempted to be started?
Old Mar 23, 2006 | 10:42 AM
Tarzan's Avatar
Basically, I want to have a hidden switch, w/o that the car would start and idle, but stall as soon as they try to drive away. I heard that it is possible to tap into just one wire in a 3d gen to achieve that. Which one?
Old Mar 23, 2006 | 10:55 AM
Josh's Avatar
why would you want it to start for them? I would think running a switch to the fuel pump fuse would be good enough, it would start and run for a few seconds then cut out.
Old Mar 23, 2006 | 11:04 AM
internetautomar's Avatar
mod or sell?
a complex setup would be to use a normally closed relay in the ecu feed wire and have the relay connected to the brake switch so that when you press the brake it grounds the relay opening the circuit and cuting off the power for the ecu which will cause the car to die
Old Mar 23, 2006 | 11:08 AM
Josh's Avatar
Sounds like something Craig Brace has done . Is there a reason you need a kill switch this complicated or do you just want to do it for fun? Are third gens a hot item in your town?
Old Mar 23, 2006 | 12:09 PM
Mizeree_X's Avatar
Getting back to his roots
Or just pull the fuel pump fuse, quick and easy.
Old Mar 23, 2006 | 02:48 PM
SurraTT's Avatar
HR Swap Pioneer
lol,
car theifs prob carry fuses
lol, or they could just pull a accesory fuse and drive off
Old Mar 23, 2006 | 03:41 PM
MrGone's Avatar
There are far far better ways to secure a car
but if you realllly wanted to, TPS -> cut ignition
I wouldn't do it though
easier to throw a switch on the fuel pump 12v or even just spend $150, but a MSD box, and run a switch off that. Or just buy a good alarm as crazy as that seems.
Old Mar 23, 2006 | 03:56 PM
Sgibb's Avatar
http://www.geocities.com/bracecraig/maxima/kill/
Old Mar 24, 2006 | 11:30 AM
Tarzan's Avatar
TPS sounds good. I want them to get an impression that the car is not running, but not too soon.
Old Mar 25, 2006 | 05:14 PM
crosbyct's Avatar
Are you then going to spring a booby trap?
Old Mar 25, 2006 | 05:29 PM
unkn0wn180's Avatar
Yeah what ever happend to using a good alarm system?
i know a mate of mine has a red switch you have to hit to start his car. but i belivbe thats because he is cheapio and has no alarm.
Old Mar 25, 2006 | 06:25 PM
CyMax's Avatar
HELLO!! He has a "Trunk Monkey"!! Lil' Fella needs time to crawl out of the trunk and begin to pound the felon. Like Duh!
Old Mar 25, 2006 | 08:38 PM
maxitech's Avatar
I might rig the power/comfort switch as such now that it as no use...
Old Mar 25, 2006 | 08:48 PM
unkn0wn180's Avatar
power = drive
comfort = comfort knowing your car wont be going anywhere, unless the fools know how to use a switch?
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
JRod28
Feb 4, 2016 11:07 AM
kirkhilles
Aug 8, 2015 10:53 AM
Blackwind
Aug 5, 2015 06:35 PM
