PLEASE, where is the "ignition signal primary circuit"?
Old Apr 24, 2006 | 03:28 PM
slicey's Avatar
i'm getting code 0201 w/ the above explanation from my haynes manual as being at fault. i can not locate what i assume to be a wire from the schematic. is it even a wire or could it be inside the ECM? my car is missing cylinder(s) at idle and jerking under acceleration. whoaaa is me, just went through dirty injectors and a coil pack problem, now this.
thanks for any info.
Old Apr 24, 2006 | 04:06 PM
diymaximakid's Avatar
maybe a short?
Old Apr 24, 2006 | 04:22 PM
Dexter's Avatar
jerking under acceleration <- could also mean you need your tranny fluid changed, did you check to see if your tranny fluid is still good?
Old Apr 24, 2006 | 04:37 PM
slicey's Avatar
DUDE, are you for real? READ what i posted, then think before you respond w/ your response!
Old Apr 24, 2006 | 04:43 PM
RockfordMax's Avatar
Back from the dead
um..... he was throwing out an opinion, and honestly, a valid one. There is no need to belittle him mr 58 posts. IS your trans fluid good? if it is, oh well, no harm done, if it isnt, could be the cause.
Old Apr 24, 2006 | 04:44 PM
slicey's Avatar
Originally Posted by diymaximakid
maybe a short?
gee, i sure would like to check that out. lemme go inspect that wire................oh yea, where the hell is! please, where are the smart orgers?
Old Apr 24, 2006 | 04:55 PM
slicey's Avatar
it's an ignition issue. code 0201 reports this. how does my car idle poorly if my tranny fluid is overdue? if your response isn't directly related to my question w/o being plausible, then don't bother posting! post count mean NOTHING, fool.
Old Apr 25, 2006 | 11:29 AM
KsuMax's Avatar
Cheesing away...
Silly you, 16 year olds know everything
Old Apr 25, 2006 | 11:40 AM
SPiG's Avatar
SomePsychoGuy
Originally Posted by 4th gen stickies
If you don't want his help then don't read it. Although his post was not directly related to the code, some of you problems may not be related to the code either. It is something to check. If you expect a handout you can't be too choosy with your responses. Age, post count, etc. might not mean much, but if you are a ***** to those who try to help you, then people are going to start to turn around and do the same to you.
Electrical problems are not something easily diagnosed over a internet forum. You might just have to take it to a shop who can test it better if you don't like what we can give you.
Old Apr 25, 2006 | 11:42 AM
kormax97
Be nice. Your 37.
Old Apr 25, 2006 | 11:49 AM
eng92's Avatar
Is it a constant misfire or intermittent?
Did you try unplugging the coils one at a time and see if there is one that did not make the misfire worse?
Is DTC 0201 the only code you are getting?
Old Apr 25, 2006 | 12:07 PM
DcMaN's Avatar
ever changed the spark plugs? Pretty much its saying check anything ignition related... Coils, injectors, plugs i would try that first. Then look at the camshaft sensor, crank shaft sensor(s). I highly doubt the sensors are bad because they are magnetic but it happens. Unplug each coil at a time with the engine running... See which one has no effect on the engine. That could be your issue i would suggest you change your plugs and fuel filter if you havnt lately.
Old Apr 25, 2006 | 12:27 PM
BlackMaxdout's Avatar
sometimes the crank sensors get loaded up with metal shavings and screw around with the signals they produce. I had to clean my crank sensor (POS, not piece of ****, it refers to which one) because it was completely covered in crap.
Also, you said you changed coils....unplug them and make sure you didn't bend any pins of the connectors. I accidentally bent one when I redid my coils, and it took me a while to figure out what it was.
Old Apr 25, 2006 | 01:18 PM
slicey's Avatar
[1] intermittent, engine not nearly shakey as when coil pack #5 died two months ago.
[2] no, just unplugged all for spraying all the connectors w/ electrical contact cleaner.
[3] only code 0201, which from the sticky is puzzling.
Old Apr 25, 2006 | 01:31 PM
slicey's Avatar
ngk plugs 2 months ago. 2 new coils, 2 new injectors, all injectors pro cleaned; all of this two months ago.
now, when i unplug each coil, i know my engine will become uniformly shakey. so what i shoud be trying to detect is wheather or not the behavior i listed in my thread has gone away? when/if this happens, i'm closer to a resolution. does this seem logical?
Old Apr 25, 2006 | 01:35 PM
slicey's Avatar
funny you mentioned bent coil pins as i did this to one when replacing my plugs. although this would really make motor run/feel crappy.
Old Apr 25, 2006 | 01:37 PM
slicey's Avatar
i'm off to have a look see at those two sensors! thanks for recent assistance, fellas.
Old Apr 29, 2006 | 02:11 AM
slicey's Avatar
update by slicey
cleaned above mentioned sensors to no avail, but alas, i found when disconnecting the plug to cylinder #1's coil pack, i've narrowed my problem down. will be testing it soon. later
jmlee44
Oct 2, 2022 02:13 PM
AaronL
Aug 8, 2020 10:31 AM
msellas
Sep 23, 2015 09:16 PM
BrandonCause
Sep 14, 2015 10:41 PM
