Will lowering your car negatively affect your car?
Will other parts get more wear and tear if you were to drop your car with coilovers or springs/shocks? Will your cv joints be affected or any other part of the car with early wear and tear?
if u lower too much ur CVs will start to go...more stress on ball joints and tie rods...and too low will make ur car handle like *****....IMO Progress in not too low and will not effect parts signicantly...they might have shortened life a little bit.......best thing to do is inspect all front end parts and replace the ones that need it...IE ball joints tie rods and axles
Any type/amount/inches you lower a car will put suspension parts under pressure..( reduce the life span)...
Obviously, if it's done right, your cv joints, ball joints, axles, etc.. will wear out but at a slower pace then if you are running negative camber...
If you want to play, you gotta pay
cv joints do wear out real quick. but with a mild drop not mcuh more stree is applied, where it will messthings up quick. i was on s-techs for a year and sprint for another year, and no problem. the problems came with a extream drop on coilovers
Lakersallday24
Jun 16, 2019 01:35 AM
soon2ownmax
Aug 13, 2015 02:19 PM
laparka66
Aug 6, 2015 09:36 AM
