Oil Blowby
Old Apr 28, 2006 | 01:35 PM
vvslavavv's Avatar
Oil Blowby
Does anyone have this mod on their 4th gen? A bunch of people are doing it to their 5th gen cars, and I was wondering if there is a point in me doing it on my 4th gen.
Old Apr 28, 2006 | 01:38 PM
motorheadwannab's Avatar
isn't oil blowby when oil gets on your sparkplug???
Old Apr 28, 2006 | 01:39 PM
vvslavavv's Avatar
I'm actually talking about this
http://forums.maxima.org/showthread....51731&t=418752
oil going out through your PCV and into the intake.
Old Apr 28, 2006 | 05:37 PM
Tim96I30t's Avatar
that is on a 3.0L...many 4th gens have done this just put the filter inline with the pcv and either get new filter when full.
Old Apr 28, 2006 | 05:46 PM
njmaxseltd's Avatar
A nice tight, well maintained engine should not have any "Oil Blowby".
There should be no reason to do anything with the stock PCV system.
All it does is let the crankcase breath nice clean air when/if it needs it.
Old Apr 28, 2006 | 06:05 PM
vvslavavv's Avatar
Tim:
Why use a filter and replace it? Can't we just use the same thing that the people use on their 3.0??
njmax:
How do you figure that? From the FSM manual "This system returns blow-by gas to both the intake manifold and air cleaner. The positive crankcase ventilation (PCV) valve is provided to conduct crankcase blow-by gas to the intake manifold."
It returns air from the crankcase (which has oil) to the intake manifold .. so wouldn't the air have atomized oil particles? Why are so many 5th gen have problems w/ this?
Old Apr 28, 2006 | 06:09 PM
Tim96I30t's Avatar
You can either use a fram G3 filter and replace or get the home depot compressor and drain when full, didn't mean to confuse you with that. Once you hook it up this way you will see all the oil the goes into the filter not the intake where and gets burned up and causes deposits.
Old Apr 28, 2006 | 06:34 PM
vvslavavv's Avatar
Tim:
Thanks. I got the home depot compressor, and will attempt to do that mod. Does what njmax said makes sense? If I have blow-by should I be trying to fix the cause, and not just put a bandaid by using this mod?
Old Apr 28, 2006 | 08:39 PM
nismology's Avatar
All motors have some level of blow-by either past the rings or valves and will leave a nice oily film in the intake tract eventually.
Old Apr 29, 2006 | 04:56 AM
njmaxseltd's Avatar
I agree, but there shouldn't be a lot of oil in the gasses unless you have a worn engine. Last time I changed my PCV valve (120,000 miles) it was actually pretty clean. So if there's no oil sludge on the PCV valve, and the TB plate is dry, then there isn't any in your intake path. I've never seen an oil soaked TB plate on any VQ on this forum. Also most on here clean the intake with various products every 6 months or so. Honestly, I don't think there should be any reason to modify the PCV system of a well maintained VQ engine.
Old Apr 29, 2006 | 05:12 AM
RA030726's Avatar
I'm nutty for Nissans
I have one installed. But it doesnt look all ghetto like the way the write up is done. Mine is under the cruise actuator. You cant see it in this pic, but thats the point.
Old Apr 29, 2006 | 06:16 AM
Iron Scimitar's Avatar
Tha Snatcher
Nice clean engine bay.
Old Apr 29, 2006 | 07:05 AM
nismology's Avatar
What does a motor being worn have to do with oil mist in the blow-by? The stock intake resonator is also called the oil seperator, to remove the oil from the blow-by gas.
BTW, i didn't say anything about oil sludge. I said there would be a slight film of oil that you can only tell was there if you removed the TB and looked inside your intake manifold and took a swipe with your finger if you have the stock resonator/oil seperator. Anyone with an aftermarket midpipe has found an oily film in their intake, guaranteed. If they haven't it's because the PCV system isn't operating properly. Also there is a Teflon coating on the TB to prevent oily build-up so it wouldn't be the best idea to check there for that. The baffle plates in the valve covers are there to limit the escape of the oil mist, but some will still end up in the intake tract.
Old Apr 29, 2006 | 10:20 AM
RA030726's Avatar
Thanks, but I have been neglecting it lately.
Old May 1, 2006 | 07:02 PM
goldmax's Avatar
What's the deal with the radiator hose? That doesn't look stock. Where does the line go from the T fitting in the middle?
Old May 1, 2006 | 07:14 PM
Kevlo911's Avatar
Kevlo for President
Mine...
Old May 1, 2006 | 08:37 PM
ThurzNite's Avatar
How often does yours fill up?
Jae
Old May 2, 2006 | 04:28 AM
RA030726's Avatar
I get a good amount of oil in my catch. Though I rarely empty it. Im lazy.
i made that for my aftermarket temp gauge.
litch
123
Jan 4, 2024 07:01 PM
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
