DTC's Help
DTC's Help
I got 3 freaking codes popping up.
P1105
P0105
P1705
I did a search and only found that the P1105 had to do with the MAP/BORO Senor, wtf is that? Any help would be great thanks. Any one know anything about the others?
P1105
P0105
P1705
You sure those are the right codes? 1105 is improper shifting into 3rd gear and the other 2 come up undefined. Did you get these codes by using a screw driver?
The MAP/BARO Solenoid Valve switches hose connections to the Absolute Pressure Sensor to measure between manifold absolute pressure and ambient barometric pressure for the ECU. These two are connected together by a vacuum line, These two codes are probably related to a common problem. Ruptured, unhooked, or plugged line. Wiring short or one is bad causing the other to throw a code also. The throttle position sensor is probably not related.
enticiveblkmax
Feb 12, 2001 06:52 AM
