Hot air
Old Apr 30, 2006 | 06:37 PM
NewEngSurf's Avatar
Hot air
Is this a typical thing wiht 4th gens. Ill randomly just have warm - hot air comming out of my floor vents. I really havent done anything to investigate this but id figure id ask if anyone else has experienced this. This happens when the climate controll was off so is it just heat from the engine? Is like a door in the ducting open or somethin?
Old Apr 30, 2006 | 06:55 PM
Cdg2125's Avatar
The vents for your AC are still open really. So its air flowing through the AC. Just because it's off doesnt mean that everything is closed. So it's really just engine heat I believe. My max does it. My old max did too. Pretty sure most cars do.
Old Apr 30, 2006 | 07:10 PM
partyraider09's Avatar
yah pretty much every car does it. its just the heat from the motor coming through the vents. in fact in my 83 porsche i had that was my only way of gettin warm during winter. that really sucked.
Old Apr 30, 2006 | 07:17 PM
Fr33way™'s Avatar
Wild for Width
Turn your climate to around 68-72 then turn it back off.
Otherwise you can press the re-circulate button.
Old Apr 30, 2006 | 07:28 PM
Cdg2125's Avatar
Fr33way that's worked for you? When I turn the temp down or do the recirculate it still ends up on my feet.
Old Apr 30, 2006 | 10:16 PM
konak85's Avatar
i think if you press the button the recirculate/fresh air button it'll stop.
Old Apr 30, 2006 | 10:22 PM
Fr33way™'s Avatar
Wild for Width
If you do what I said, the air at your feet is now just ambient temp.
If you do the recirculate this should stop it.
Old May 2, 2006 | 05:54 AM
Cdg2125's Avatar
Ok thanks I'll try it again next time.
Old May 2, 2006 | 07:01 PM
GStrength's Avatar
Lol for some reason when i have the recycle button pressed in wit the slider all da way on cold the air flow is rather cool, on my 96 GLE on the other hand never had that problem wit the air flow i never felt **** coming from my vents only on my 97 gxe
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
Miket2006
Mar 1, 2021 03:55 AM
Justin Kroll
Oct 1, 2015 07:03 PM
